Sound quality difference with higher sample rates
Hi All,
I imagine this has been covered ad nauseum (especially when the 002 debuted) but wondering what people's thoughts are regarding an increase in audio quality when using higher sample rates. To my ear, I hear very little difference in tracks I've recorded at 44.1 and 96. I imagine acoustic instruments and vocals would particularly benefit from higher sample rates but I'm still not hearing much difference. Your thoughts? J.D |
Re: Sound quality difference with higher sample rates
Higer sample rates are usful for internal processing (plug-ins are better accruacy in higer sample rate)
the human ear con not hear the full benifit of 96KHz (and above, i cant not see any point of 192KHz at all) as mentioned above its usful for internall processing and the higher frequencies are clearer. and yes things like acoustic tracks you will hear more of a difference than say with rock or other music. however if you ar going to be putting ur finished product onto cd you will have to down sample to 44.1KHz any way
i never use 96Khz i do not see the point as there are only relitive small advantages that you will actually hear (when you will have to down sample anyway) and it required twice the system resorces i work generally work at 44.1 in 24-bit or sometimes 48/24 the advantage of recording in 24bit far off sets the extra storage space and does not require faster processing however with saying that i would not buy a main piece of equipment that did not support 96Khz bacause im sure at some stage i will be dealing with 96KHz and the 96K converters are a generally better quality (i stress the generally while comparing similar rage of converts, lots of people still happy using their 001 though) |
If you've got Reason you can do a little experiment and change the resolution while it is playing back a song. If you play something and switch between 44 and 48 you can hear something happening to the to the sound. The top seems more defined and I think everything seems to have a little more depth. Almost like it's come a little more into focus.
Interestingly if you put the resolution up to 96 there isn't much of a change. On my set up anyway.
http://bobbybloomfield.com |
Theoretically, you could capture freqencies up to 48kHz (Nyquist frequency) when recording at 96k. If you high pass your recordings at 18-20kHz, you could make a song that only your dog could hear.
www.xeetstreetband.com Intel 486 75Mhz - 16Mb RAM - Audiomedia III - Session Software |
I would have to be careful of that, because my dog is a nasty critic. And I have a NyQuil theory, but I think that's a different thread.
www.carvelstudios.com |
The only person that can hear and mix songs at 192khz and in 24 or 32 bit is Bob Katz.
Ill suffer winter alone; ten thousand miles from home... |
it sounds to me like you are stating that 192KHz is pointless because the human ear can only hear 20Hz-20KHz (it can actually go a little higher with harmonics), but 192KHz sample rate just means the audio is sliced up 192 thousand times per/second which allows for a clearer more acurate signal to be stored onto your harddrive.
www.klarityrecordingstudios.com |
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Hmmm...
Actually Phil, You are wrong. Roy Howell makes the perfect converters in his basement. They should be at NAMM this year.
PT9 A&H ZED-R16, no playback at higher sample rates | redbull | Windows | 10 | 09-20-2012 10:04 PM |
ADAT, AES, higher sample rates | Uli Rennert | macOS | 0 | 04-19-2011 08:23 AM |
44.1 vs. higher sample rates | Stacyodell | Pro Tools TDM Systems (Mac) | 88 | 09-22-2007 10:37 AM |
any arguments against higher sample rates like 96? | Tito Ricci Arballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-08-2004 09:33 PM |
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2003 08:36 AM |
