Do audiosuite plug-ins add latency?
If not, would it be a good idea to process all rtas plugs with the audiosuite equivalents? Would it make a clearer mix?
Re: Do audiosuite plug-ins add latency?
As audiosuite renders a new file in place of the old one, there should be no delay. Latency occurs when the system takes time to process streaming audio.
while it does eliminate the need to compensate for latency, it makes your ability to tweak/adjust the plug on the track casue it is written to the track. You can of, course undo, or recall the raw track, but it is much easier to reach for the plug and tweak as needed.
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
learn to use playlists when messing around with audiosuite plugs...
i love my apple iPhone! |
good point.
This makes complete sense to me. I think it has nothing to do with latency tho, but it does have ALOT to do with CPU processing.
audiosuite your tracks after you tweaked them, then turn off the plugin. |
Imposible for me, as I'm ALWAYS tweeking!!!!!!!!!!!
Joz
"I never hit a women with her clothes on!" |
The only reason why an RTAS plugin would induce latency is if it did it intentionaly. Both EQ's and Compressors (or any other non-linear non-waveshaping type plugins) need a few samples to be able perform the formuli that make them work. EQ's typically (and fundamentally) need 2-3 samples and compressors sometimes more for proper processing. Some plugins implement these formuli without inducing latency, but technically aren't doing it 'correctly'. However, if it sounds good, it doesn't matter!
www.xeetstreetband.com Intel 486 75Mhz - 16Mb RAM - Audiomedia III - Session Software |
as far as i know as doesn't adds latency, you can prove this clicking on the selected track to see if adds latency...that was the way that i reduce latency on some tracks and on others use time adjuster or just nudge them
The only time audiosuite will relay delay your region is if you do a drastic pitch-down of an audio file. Then you can just elastic it back in place. But other than that, it's no latency!
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Audiosuite latency? | 832 M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-13-2012 03:57 PM |
AudioSuite Plug-ins not showing on track plug-ins | dappmasters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-23-2006 06:35 AM |
Audiosuite latency | gitarrcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-21-2005 05:34 AM |
audiosuite plug ins problem ...arrrggg audiosuite | hotcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-23-2004 02:35 PM |
Waves AUDIOSUITE latency | Darin Donovan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-31-2003 09:11 PM |
