Old 11-12-2003, 12:41 PM
Oona Oona is offline
Default space bar
when i press spacebar ,program does not respond to play in anny of the audio files??
Old 11-12-2003, 12:48 PM
RobMacki RobMacki is offline
Default Re: space bar
need
more
info
Old 11-12-2003, 01:02 PM
2 start play,u have 2 press the the spaebar,rite!?. I press the spacebar ....... line does not move... no sound
there . what 2 do
Old 11-12-2003, 02:15 PM
Extreme Mixing Extreme Mixing is offline
The first thing I'd try is reformatting all of your drives and reinstalling your system and programs...
OK. DON'T DO THAT!
I still think we need more information. I read another one of your posts and didn't know what to say about that problem either. Relax. We all started out not knowing anything about the system.
Do you know where the cursor is?
If you don' t press return. That will return the cursor to the start of the file.
Maybe your screen just isn't parked where the cursor is playing. You can go to the options menu and select a scroll option that is better for you. I'm thinking you have "no auto scrolling" selected, and you probably have "timeline follows insertion point" selected in your preferences. That makes Pro Tools operate like a tape deck, so the space bar plays, then stops, then resumes play where it left off and there's probably no music there.
If you want to zoom out farther to see more in the edit window, press <apple and r>. If you want to se the whole session, double click on the little magnafying glass at the top left of the screen.
Try those things and check back.
Hopefully, the guys from Matchbox 20 aren't waiting for you to record them...
Steve Shepherd
Extreme Mixing
Old 11-12-2003, 02:43 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Turn off preroll????? It might be set to some unreasonable length!! Ive been stung by that in OMFs!!!
IMDB
Old 11-12-2003, 02:47 PM
auckland yobbo auckland yobbo is offline
The little clock in the lefthand of the transport window isn't flashing blue by any chance is it?
Oona, more info in your questions would make them easier to answer.
Cheers
-Yobbo
Old 11-12-2003, 03:29 PM
In the Transport Window.. is Transport=Pro Tools? In the Session Setup Window, is clock set to Internal? Is the timeline and edit window linked?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-12-2003, 08:16 PM
Natural Sound Natural Sound is offline
and one more..
If you clik on the play button in the transport window, will it play?
If not, then the problem is not the space bar.
from there, follow Rails suggestions.
Thomas Anthony
Natural Sound
Old 05-27-2010, 09:42 AM
jermahusa jermahusa is offline
"you probably have "timeline follows insertion point" selected in your preferences. That makes Pro Tools operate like a tape deck, so the space bar plays, then stops, then resumes play where it left off..."
This was an answer to an issue that just popped up for me! Thanks. I must've fat-fingered something to engage the preference, because I didn't change anything in the actual preference menu...
I had a very irritating session with a client last night due to this one!
Thanks again!
Old 05-28-2010, 08:34 AM
Sean Russell Sean Russell is offline
Thanks again!
it's the 'N' key.
... but does it help the chorus?
Space (AAX/Native) not authorizing Space 11.1 YYR123 AAX Plug-ins 12 01-29-2014 01:33 PM
Space not able to 'see' all the presets that were created with TL Space ArKay99 AAX Plug-ins 12 01-29-2014 03:56 AM
Any new news on TL Space or Space evilstudios AAX Plug-ins 15 12-15-2013 05:03 AM
TL-Space Native and TL-Space TDM question ArKay99 RTAS & TDM Plug-ins 3 08-04-2013 08:54 PM
space allocation problems - when there's heaps of space! cibot Digidesign Hardware & Software 2 10-18-2002 05:08 PM
