Old 03-19-2007, 06:34 AM
depeche_cerati depeche_cerati is offline
Default AM2 and DIGI001
Hi Guys:
I was trying to upgrade my PC system and keep my Digi001.
What about the new MOBOs AM2 for AMD. Do they work?
Thank u Very Much
BRGRDS
Old 03-19-2007, 06:46 AM
SixChurchStreet SixChurchStreet is offline
Default Re: AM2 and DIGI001
I do not believe there are any problem with the AM2 socket.
Also look at Socket 939 boards. You can get them pretty cheap cause they are phasing out, but most can still run Athlon 64 X2 Dual Core CPUs. So if you end up upgrading to a 002/003 and PT7.x at some point you can start using Dual Core.
I just upgraded my Digi001 system from...
MSI K7T-Turbo2 (VIA) motherboard, Athlon XP 2400+ cpu, 512MB PC133 RAM, Win 98, PT 5.1.1
to...
Asus A8N-SLI (nForce4) motherboard, Athlon 64 3700+ cpu, 1GB PC3200 RAM, Win XP Pro, PT 6.4
And if I ever step up to the 002/003 like I was saying, I can plop an x2 Dual Core cpu in there and i'm good to go.
In any case, I'm pretty sure AM2 is perfectly fine. Others that are using it may want to back me up on this though.
kip
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 03-19-2007, 08:11 AM
What video board are u using with PTLE?
Thanks for ur prompt replay.
BRGRDS
Old 03-19-2007, 08:12 AM
sunburst79 sunburst79 is offline
You can use Dual Core AM2 with a DIGI 001. But you MUST disable one core in Protools in order for Protools to run correctly .
I answered this question in your last post.
6.4 will not run on dual core computer!
I don't own a 001 or a Dual core computer. but I beleive that disabling one core in PT's RTAS setup dialog doesnt have any effect on the processer function of the rest of the computer. In other words only PT is running on 1 core the rest of the computer can see two cores.
Fellow Protoolers correct me if I'm wrong there
I certainly would not build a single core machine at this point in time.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-19-2007, 08:25 AM
I'm using an old school Voodoo3 2000 16MB PCI video card. It works just fine for what I need, and doesn't tax my Power Supply or anything.
As far as this whole dual core thing, like it said, get a board that can use the Athlon 64, and also can use dual core cpus. Use the Athlon 64 cpu with your 001 and 6.4, and when it comes time to upgrade, get yourself a dual core cpu and swap it in.
Old 03-19-2007, 08:42 AM
Do you know if somebody did this (disable one Core) and the PTLE worked?
What about the pci expess video boards?
Best Regards
Old 03-19-2007, 08:45 AM
I think its OK to use a actual dual core processr as long as you've set up PT to use 1 Processer in the Playback Dropdown menu. No need to swap processers down the road.
Scott
Core 2 Specs Page
Old 03-19-2007, 09:34 AM
Cool, that is good to know.
Unless you want to go with the single core now to save money, then get a dual core later when the newest and greatest thing is out, and get that cpu for cheaper too. therefore saving money in the long run.
This is of course a gamble as you never know for SURE that something is going to be cheaper when you get around to wanting it. Though with electronics this happens more often then not.
I've saved a TON of money by laying a few steps behind everyone.
Old 03-19-2007, 10:38 AM
Vlad Drac Vlad Drac is offline
I second that.
I just finished building a a8n-sli deluxe w/an Athlon 4000 single core for my digi001, and it kick *****, but when I'm ready to move to the 002/003, I can used the same board and install a dual core processor and... whala!
-Vlad
Old 03-19-2007, 10:50 AM
Hi Vlad:
What video board are u using with DIGI001?
How was the installation of the new system? Easy? did u have to disable things in the mother?
BRGRDS
***help with Digi001*** DJDelphi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-12-2006 07:10 AM
Digi001? Vengeance Pro Tools TDM Systems (Win) 1 01-13-2003 02:46 PM
Digi001 vs. Digi001 Factory? geminirand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-07-2002 10:17 AM
Mixer into Digi001 or Digi001 into Mixer? Please discuss... MikeC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-21-2001 12:29 AM
Digi001 misrule 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-23-2000 10:41 AM
