Old 07-28-2006, 11:14 AM
Runs with Scissors Runs with Scissors is offline
Default Socket AM2 boards with Pro Tools LE
So it's official, I just got an ASUS MXNPV-VM motherboard to work seamlessly with Pro Tools on my Digi001. If I can do it on my 001, you can do it on your MBOX, 002, or firewire 1814. The results were stunning on a single processors system. I had to do some system altercation, but it works. So this system is under $600.
I had to modify my boot.ini file and use the current PACE Ilok Driver. I needed to change BOTH of those things to get past the blue screen of death.
I can't remember exactly everything I did, but there is a special hotfix from Microsoft to fix a dual core processor issue and a driver for the processor from AMD that were BOTH UNNECCESARY.
I flashed the BIOS of the motherboard to version 0303 to fix a HyperTransport issue.
And I disabled everything that I did not need in my device manager, msconfig, and BIOS.
68 Mono Dverbs on 1 3500+ processor. That's right. 1 processor. And not even a fast one. The 3500+ is a low end dual core Athlon. Imagine how many you can have with a 4800+...
So I hope this helps someone.
FYI, AudiomediaIII cards wont work on this socket. Maybe they will, but I kept getting DAE errors.
Runs with Scissors
[email protected]
Old 03-21-2007, 08:35 AM
depeche_cerati depeche_cerati is offline
Default Re: Socket AM2 boards with Pro Tools LE
Hello Run:
A long time passed away.
I was trying to upgrade my system using the DIGI001.
Do you recomend the AM2 soket?
How was your experience?
BRGRDS
2 video boards in Pro Tools HD3 Delart Pro Tools TDM Systems (Mac) 1 10-16-2007 01:17 PM
what is an AM2 socket? popmatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-20-2007 08:19 AM
AM2 Socket Asus georgej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2006 09:53 PM
AMD is merging its 939 and 754 to a new socket! Matt P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 09-11-2005 05:41 AM
P-4 systems, Socket 423 or Socket 478?? Rudger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 10:25 PM
