Old 03-19-2007, 11:06 AM
Default Re: AM2 and DIGI001
You may have to disable one of the Cores in Windows Task Manager also. I'm not sure on that. But if you found a deal on a smokin X2 processer and board, I would buy it. The same holds true if you can find a deal on a higher clocked single core bundle. Hopefully some one running a 001 with a X2 proc will chime in. If in doubt go single core. Just make sure the chipsets compatible.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 03-19-2007, 02:38 PM
Vlad Drac Vlad Drac is offline
Hi Vlad:
What video board are u using with DIGI001?
How was the installation of the new system? Easy? did u have to disable things in the mother?
BRGRDS
Very easy!
I did have to disable a bunch of stuff in the BIOS (network stuff, RAID controllers, etc.), but I disabled everything I was sure I wasn't going to use, so I'm not sure if there would have been conflicts...
I do recommend, however, that you install Windows with the default settings in your BIOS, or it won't recognize everything, then disable what you want, then install PT.
As far as video card, PT doesn't eat up much video power on it's own, so I just got the cheapest PCI-E card I could find that had a fan and dual monitor support. I think I found a PNY for around $50 after rebate.
Everything has been smooth sailing since.
For the 001, it is more power than I can utilize. I just hope it'll still hold up when I upgrade to a dual core chip and an 002/003.
-Vlad
Old 03-23-2007, 10:08 AM
depeche_cerati depeche_cerati is offline
I still want to know if somebody tested the digi001 in a motherboard with soket AM2.
BRGRDS
Old 03-23-2007, 12:57 PM
Micah777 Micah777 is offline
I'll tell you first hand that I just build a new system with a AM2 socket and I'm getting H/W interrupt errors left and right. too low a buffer and I get (-9093) errors I move it up and I get (-9129) errors. At the moment I can't run a single second of audio before the errors fly. My setup is:
Athlon 64 X2 +3800
gigabyte MB GA-M61PM-S2
1GB RAM
SATA 3GB system drive
DIGI001
Micah
MICAHELLIS.COM
Old 03-23-2007, 03:37 PM
Thank for your reply.
But you have an Athlon 64 X2 and this is a known issue with the DIGI001. Sorry Man.
Old 03-23-2007, 03:40 PM
I still want to know if somebody tested the digi001 in a motherboard with soket AM2 with a single CORE CPU.
BRGRDS
Old 03-24-2007, 12:54 PM
Thanks for the info. That at least saves me headache time trying to troubleshoot this. Since I already have all the equipment I'm going to buy a single core processor and try it out. I'll let you know what happens if you can wait a few days.
Micah
MICAHELLIS.COM
Old 03-27-2007, 01:47 PM
BRGRDS.
Old 03-29-2007, 02:45 PM
I just put in a Athlon 64 +3800 Single Core processor into the setup stated in my earlier post and PT seems to run smoothly with it. I opened my biggest project which pretty much pushes PT to it's audio and aux track limits. the project also has several Waves RTAS plugins running in it. CPU usage is hovering around 40-45%. I only ran it for a couple of minutes but compared to what I was going through with the dual core I'd say it works beautifully.
Micah
MICAHELLIS.COM
***help with Digi001*** DJDelphi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-12-2006 07:10 AM
Digi001? Vengeance Pro Tools TDM Systems (Win) 1 01-13-2003 02:46 PM
Digi001 vs. Digi001 Factory? geminirand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-07-2002 10:17 AM
Mixer into Digi001 or Digi001 into Mixer? Please discuss... MikeC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-21-2001 12:29 AM
Digi001 misrule 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-23-2000 10:41 AM
