conversion confusion
I have a 16 bit session, imported 16 bit audio files but at bounce to disk when I select 16 bit, Iīm prompted to choose between converting on the fly or converting after bounce. What is it converting to?? I musty be missing something because there shouldnīt be any conversion going on...
any help is good thanks |
Re: conversion confusion
you must have selected stereo interleaved. that will cause a conversion, but not a dithered or samplerate conversion.
i love my apple iPhone! |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by da BaSsTaRd!:
you must have selected stereo interleaved. that will cause a conversion, but not a dithered or samplerate conversion.<HR></BLOCKQUOTE> good guess but no, itīs a drum mix and Iīm bouncing to 2 mono tracks (stereo NOT interleaved) I can chjoose 24 bit and the options for conversion go away.... thanks [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] |
According to Digi, even with 16 to 16, there are still conversions at work due to internal processing at higher bit rates. See p. 321 Reference Guide. That's why they suggest you always use Dither Plug at mix.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Jorge442: I have a 16 bit session, imported 16 bit audio files but at bounce to disk when I select 16 bit, Iīm prompted to choose between converting on the fly or converting after bounce. What is it converting to?? I musty be missing something because there shouldnīt be any conversion going on... any help is good thanks<HR></BLOCKQUOTE> |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by JMS40:
they suggest you always use Dither Plug at mix. <HR></BLOCKQUOTE> thanks so much, I learned something for today. |
Check your sample rate. You may have it set to 48k. If this is the case it will "convert" the file to 44.1khz.
mix2much
nah, I already checked. I barely ever touch 48k anyways. I think itīs just what JMS40 said it was. I got these 16 bit sessions from a local studio, they mustīve been using older PT hardware I suppose. I thought it sounded decent and decided to keep everything at 16 bit, except for the mastering session. thanks for the replies! jorge |
I can chjoose 24 bit and the options for conversion go away.... thanks [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]<HR></BLOCKQUOTE> Sounds like maybe you have a 24 bit session. You can check at Windows > Show Session Setup Steve |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by cubasteve:
Sounds like maybe you have a 24 bit session. You can check at Windows > Show Session Setup Steve<HR></BLOCKQUOTE> I agree, but already checked that also. |
ADC Confusion?? | surroundnoob | Post - Surround - Video | 16 | 03-26-2011 01:57 PM |
EA was there now not confusion...? | mafiacondon | Pro Tools TDM Systems (Mac) | 3 | 08-18-2010 06:51 AM |
ADC confusion | Matt@ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-10-2008 09:49 AM |
PT III CONFUSION | FrostyWhite | Digidesign Hardware & Software | 2 | 03-22-2006 10:51 PM |
mic pre confusion | willbgoode | Pro Tools TDM Systems (Mac) | 13 | 12-07-2004 07:18 PM |
