Old 05-02-2023, 08:11 AM
Svante Biörnstad Svante Biörnstad is offline
Default TC metadata??
Received an AAF from Media Composer. I recorded the original audio and I know it had TC on it. It was synced with picture and somehow the TC was lost. Boring but sometimes editors screw things up. I had to sync things manually, all it takes is time. But, and here’s my question. How come there’s time information in the clips but not in the metadata fields? The numbers are correct but PT couldn’t reconnect to the original channel files that I needed.
Skickat från min iPhone med Tapatalk
Old 05-04-2023, 04:57 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: TC metadata??
If the WAVs you show were created by Media Composer while exporting the AAF that you loaded into PT, then I'm not sure either. The AAF obviously has the correct source TCs in it if they are displayed in the PT clips.
I get in future that you would like this to work in PT if you see this again, but if it's a bigger project and you can't, I'd expect you'll be able to assemble all original media with the EdiLoad assembly window. It can load an AAF or even a PT session to get the correct source TCs, then use this to link to your original WAVs.
Best regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 05-08-2023, 11:50 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
In MC's export AAF option there is an option to select use "Use Edit Protocol". If this was not checked by the editor it MAY have been the culprit in your issue.
FWIW A quick look at the latest version of MC shows the new MC Export to Pro Tools/ Export as Pro Tools session. This has an option to "Embed Field Recorder bin Metadata in audio" (not checked by default)
I now prefer this option over the traditional MC AAF export.
Old 05-10-2023, 11:02 PM
trevora trevora is offline
The 'edit protocol' was something to do with >2Gb files I think - not sure what would reset start TC to zero.
Old 05-11-2023, 06:36 AM
quadraphonics quadraphonics is offline
I have seen TC stripped out of audio files if the audio went through any kind of transcoding process. In my case, sending the audio through a FFMPEG script to convert from 16/44.1 to 24/48.
Not sure if that applies here, but it might be worth looking into to see if the editor transcoded the audio to a format and didn't keep the metadata.
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
HTML code is On
Metadata Samba Pro Tools 11 4 09-30-2014 04:49 AM
Metadata and Windows Help Please Andy1138 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-26-2010 08:10 PM
Metadata in Pro tools meathman Post - Surround - Video 1 07-08-2007 08:13 AM
bwf metadata to FCP viaspiaggia Pro Tools TDM Systems (Mac) 0 06-14-2007 06:29 PM
Metadata in timeline Studio Studio Pro Tools TDM Systems (Mac) 4 12-20-2006 01:35 AM
