how do i shorten my song
When i first laid the drum tracks, i did the drums all the way to the 6:30 mark…..then after i added the other instruments the song only went to 3:40, so i cut all the extra drum notes…..but when i click the "end of song" button in the transport window, the end of the song is still 6:30……i dont want there to be a big space between 3:40 and 6:30, when i bounce the song to disk…..how do i make my song end at 3:40? so there is no big space at the end?
Re: how do i shorten my song
When I want to get rid of clips at the end that I don't need, I click right after the end of the song in the Bars|Beats ruler (so all tracks are highlighted), and then hit Alt+Shift+Return. This should select everything from the cursor and out on all tracks, and then I just hit delete.
If it is a MIDI track just switch the track view to Regions (this will look like large blocks with the notes within the long blocks... and shorten the block (not the notes, in fact If you shorten it to where you have MIDI notes you will see the notes disappear as you shorten the region, so you could have just done this in the first place and it would both remove the notes and shorten the MIDI region, allowing the END of your session to be at the end of your MIDI region)
All you did is remove the notes... You also should remove the region.... http://www.youtube.com/watch?v=1-rmJB3x0kw |
lol... Thanks Albee... What can I say Im kinda old school...
Pretty basic stuff, easily found in the manual.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Shorten Song | WaddyP | Pro Tools 10 | 6 | 07-14-2013 01:32 PM |
How to shorten a wav loop | baconpatroller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-08-2011 07:42 PM |
Can't Shorten song | rjh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-06-2010 09:14 PM |
How to shorten a session? | Patrick Jackman | Tips & Tricks | 7 | 09-19-2004 03:21 PM |
How to shorten a session? | REtroJECT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-18-2003 01:54 PM |
