please HELP | Efficient way to do SPOKEN AUDIO CD
Hey all,
I'm hoping someone out there has some suggestions for an efficient way for me to record voiceover work in PT TDM 6.4.1. I am producing a Spoken Word Audio CD with 60 track marks (approx 60 min) I need to record approx 60 min of script reading, and drop CD track marks every minute or so on the fly , then export as 60 seperate CD audio tracks (for a 60 track Audio CD). #1. Is there a way to batch export (or bounce to disk) all of the seperate tracks with one command ??? i.e. and not bouncing each selection to disk one at a time (60 times) #2. Is there a way to assign "create memory location" command or drop a track marker to a MIDI key??? #3. Any other insight you can offer is certainly welcome. I've been a frequent reader and I occasionally post to this forum since 2001. This has always been a great community of engineers/producers and audio enthusiasts. Im really counting on you guys for some help. Thanks! Steve TDM6.4.1/MIX24/OSX/G4-450/MagnaExpChassis
PT HD4 10.3.8 / Mac OS 10.8.2 / Intel Core i7 3.4Ghz / Heat / X-Form / McDSP / Eventide / Soundtoys / UAD-2 / Ableton Live 9 Suite / NI Komplete 12 |
Re: please HELP | Efficient way to do SPOKEN AUDIO CD
#1: To export a regions without having to bounce:
Make separate regions for each track that will show up on CD. You can do this by selecting the first minute, then press cmnd+E. Then select the second minute, cmnd+E. There are also other ways to do this. Once you have regions where you want your CD ID markers to be, select all of the regions and press cmnd+shift+K. This will bring up the "Export Regions" dialog box. Check your settings and then press OK. Poof! Faster-than-real-time export. Note: this only exports the raw audio. If you need plug-ins applied, you'll need to bounce to disk or use AudioSuite prior to the "export regions". Jeff D. |
In my setup I would bounce the whole session of 60 segments to disk as one Stereo 16 bit file. I would then move it over to my PC, and manually insert CD markers and create the CD, with Wavelab.
...for system configuration info see my profile (Click on member name) |
blairl,
WOW, that's cool. Thanks for sharing!! Jeff D. |
Great! I believe that's what I was looking for. Again, thanks to both of your for your help.
Soulsytem
Help...Recording spoken words | ClaudeM | Tips & Tricks | 28 | 08-19-2013 01:52 PM |
538 numbers spoken, how to rename them ? | vanhaze2000 | Pro Tools 10 | 4 | 12-22-2012 12:02 PM |
The People Have Spoken | edadema | Pro Tools 10 | 121 | 11-06-2011 01:37 AM |
Apple has Spoken (FCPX) | Greg Malcangi | Post - Surround - Video | 1 | 06-29-2011 07:35 AM |
please HELP | Efficient way to do SPOKEN AUDIO CD | soul | Pro Tools TDM Systems (Mac) | 3 | 03-24-2005 07:24 PM |
