Old 11-17-2019, 05:41 AM
DAPG DAPG is offline
Default Re: Bug in new video engine 2019.10
I can confirm that I am also experiencing this looping bug. I can get it to stop if I make a cut in the video track.
Roy Machado
Dallas Audio Post
Old 11-17-2019, 08:11 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
DNXHD36 made as part of AAF
by Media Composer.
IMDB
Old 11-17-2019, 09:30 PM
tklaavo tklaavo is offline
This has happened to me as well, and more often now with 2019.10 - but I have seen it once or twice before in some earlier version.
I have two video tracks for testing purposes - one is Quicktime Prores Proxy, the other is MXF dnxhd. When it happens, I activate the other video track which then works as usual. I think it happens more often with using the MXF file. Haven't tried the cut method yet, thanks for the tip.
Tuomas Klaavo
Helea Sound Post Production Oy
Old 11-17-2019, 10:33 PM
gwhatley's Avatar
gwhatley gwhatley is offline
Here too, Pro Res LT and HQ quicktimes. Toggling the video online button on the video track is the momentary fix.
Happens more often when editing as opposed to mixing or just playback.
Work in features and TV, project length not a factor.
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 11-18-2019, 09:18 PM
mhuang mhuang is offline
noticed the same "freeze frame" "loop pic" bug here today on 2019.10
Prores proxy
I actually encounter this bug way back in PT10, something to do with some codec issues, but didn't haven't gotten it since post PT10 until today.
Old 11-19-2019, 05:30 AM
Norad155 Norad155 is offline
Same here... have experienced with ProRes and DNxHD
Random Looping
Video won't play
Video won't stop
2019.10 "new improved" video engine is trash.
IMDB
Old 11-19-2019, 06:18 AM
henningaround henningaround is offline
I have seen nothing of the errors above. Been working with 2019.10 now for a week or two with Decklink Studio2 and Aja Kona3G Card. Always QuickTime Movies with DNxHD36 Full HD. Have you guys tried different combinations of the video drivers (Aja or Balckmagic depending on your cards...)? I think it's version 10.11.2 of the Blackmagic driver on a macOS 10.12.6 here or Aja 15.0.1 on macOS 10.12.6.
Session is not too big. Stereo TV Mix on a HDX2 or HDnative system with ~ 150 voices used.
Old 11-19-2019, 06:58 AM
quadraphonics quadraphonics is offline
I have also been having odd issues with 2019.10 AVE.
I have gotten AVE errors without video in the session. Choppy playback.
The oddest one that I have had is when I would import video into a session and the video settings wouldn't change automatically to match the video format. Pro Tools used to do this. (ie, if I imported a 29.97 video into a 23 session, previously it would play the video back at 29.97 and let me know there was an issue. Now, it tries to play the video back at 23.98)
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 11-20-2019, 07:30 AM
The only thing I noticed is that the new "threshold" for loop playback is now at 1second. Any selection under 1s won't be looped. In 2019.6 and older you could easily loop a 15 frame and lower section. Maybe that's to reduce the amount of errors you're all seeing?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 11-20-2019, 02:12 PM
Meads Meads is offline
Which is totally annoying, btw.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
