Blackmagic help..?
Hey all,
Just got the Blackmagic Intensity Pro installed.... All's good except the picture is zoomed in so much that I'm losing about 20% of the picture all the way round on any of the settings available on either of the two screens I've tried.... Overscan...? None of the settings on the Blackmagic Settings panel seem to deal with this... Any thoughts? What settings are people using on theirs...? I'm using DNxHD codec, PAL, 24fps Video Thanks in advance
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
Re: Blackmagic help..?
Got it sorted.....
I'd accidentally loaded the H264 version of the video file, not the DNxHD one. DNxHD and ProRes versions both play back as they should. I'm surprised that H264 doesn't work as it should.... I know it's not a great format for most things, but I thought it would at least play at the correct size... Weird....!
I am actually having this issue with even standard dvpal files. None of the TV ratios solve this problem. It never happened on my older advc110. You play prores? It should be a very large file and heavy on the cpu.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
I usually convert everything to Pro Res to work with. |
Been running it on the Apple screen till today. ProRes and DNxHD both seem to behave pretty equally.... Similar file sizes, and play nicely with PT. So long as you have the video on a dedicated drive then it's problem free.
Isn't DV fixed to 4:3 ratio..?
You can chose 16:9 or 4:3
How big is the ProRes or DNxHD file for a reel (approx 20 min)?
Ok....
Can you change the size of the image (re-export it smaller) in QT Pro?
Are you asking about HD or standard def file size? A 20min PAL prores file with no audio is appx. 6gb |
Also found AJA DataRate Calculator for the desktop.
10.2 Blackmagic Cards? | Audio_Vision | Windows | 3 | 12-07-2012 07:44 AM |
AJA and Blackmagic in the same Macpro ??? | vudoo | Post - Surround - Video | 7 | 09-22-2010 09:06 AM |
Blackmagic confusion | jimlongo | Post - Surround - Video | 8 | 07-25-2010 11:31 AM |
Blackmagic Performance | tateaudio | Post - Surround - Video | 15 | 04-30-2009 12:12 PM |
PT8 and blackmagic........ anyone? | Ale | Post - Surround - Video | 23 | 03-02-2009 08:21 PM |
