  #41
Old 06-10-2013, 11:41 AM
tunes7 tunes7 is offline
Default Re: BUG? selecting midi track arms record for selected track
I've had the same issue and spent way too many hours trying to hunt down a definitive answer. I finally got thru to someone at M-Audio who said that Hypercontrol is not working with the current ProTools versions which is causing the auto record arming for midi and instruments. If you de-select the M-Audio keyboard from the Peripherals/Midi Controllers menu - this will bypass hypercontrol and you can use the keyboard as a midi controller via the USB connection -> Apple midi setup. Bummer since HC with PT was the reason why I bought the keyboard in the first place.
M-Audio is now independent from Avid - so unless Avid chooses to fix the HC bug in PT, it's probably not going to get fixed.
Selecting Instrument Track Auto Rec Arms Connor Pro Tools 11 1 07-26-2013 06:18 AM
Selecting instrument or midi track automatically arms record tunes7 Pro Tools 10 4 05-03-2013 02:51 PM
Shift + Option + Record Enable not working with MIDI and Audio Track selected, why??? enzomolinari Pro Tools 9 0 07-20-2011 07:00 AM
MIDI Input Problem - Selected Track vs Record Enabled salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2008 07:42 AM
record track un-arms after stop! soundwavve Pro Tools TDM Systems (Mac) 3 07-30-2008 08:16 AM
