Old 07-03-2013, 06:24 PM
JayJJimenez JayJJimenez is offline
Default Strange Sound Issues
Hello, I have recently benn having some strange issues with Pro Tools LE 10. It seems the audio I record just randomly stops playing. It begins with the audio stopping and a high pitch noise playing. I press stop & the high pitch noise is still being transmited through the level meter on the mono track. I press play again and the track display no signal and no audio is transmitted. If i restart the project everything is fine. The odd thing about this is that the stereo instrumental i am recording over will still play. Any suggestions?
Old 07-03-2013, 06:27 PM
Default Re: Strange Sound Issues
Mac OSX 10.6.8
Mbox Mini v3
Pro Tools LE 10
Old 07-03-2013, 08:17 PM
Southsidemusic's Avatar
Originally Posted by JayJJimenez View Post
Mac OSX 10.6.8
Mbox Mini v3
Pro Tools LE 10
Hi
Do you have a bit more info like harddrives and what you use for recording and what drive as system drive, make and speeds etc..
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-03-2013, 08:27 PM
currently tracks are being played off of External Hard drive, where would i find the rest of the information at?
Old 07-03-2013, 08:50 PM
Hi Jay
I would look at the actual drive, you need to look at the speed and size and prefferably the model aswell. The recording drive has to be atleast 7200rpm aswell as should the system drive, not be WD Caviar Green = Toxic for PT and whatever else you can find.
Also, do you have the latest drivers for Mbox 3 and what is your buffer size and do you use delay comp etc
The latest Mbox drivers are important download here : http://avid.force.com/pkb/articles/e...nload/en375651
Also, have you trashes preferences and all that explained here http://duc.avid.com/showthread.php?t=300050
Best Regards
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-09-2013, 08:27 AM
I trashed the preferences & the problem still seems to persist.
Here is an updated information
Macintosh HD 3.06 Ghz Intel Core i3
OSX Version 10.6.8
Mbox Mini v3 1.1.3 Firmware 0.07.0
Pro Tools 10 10.3.5
4GB 1333 MHz DDR3 RAM
Flex Drive Pro FW800 1 TB
I have trashed preferences, reinstalled Pro Tools, deleted databases.
As I playback recorded vocals sometimes the audio stops and a signal is just played over a track. Even when the session isn't being played. If i replay the session, none of the audio files will play, no signal is sent through the individual tracks either, except the stereo instrument track seems to be unaffected by this glitch and will continue to play.The only thing that seems to resolve this issue is taking all recorded tracks making them inactive & then active. This resolves the issue for a brief amount of time.
Old 07-12-2013, 11:11 AM
Strange Issues With PT10 zsetian macOS 2 01-09-2012 05:43 AM
Very strange audio issues AudioB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2011 11:21 AM
Strange PT crashing issues; please help!! ee8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-26-2007 10:44 AM
Strange grid issues. Help? Brooklynite Pro Tools TDM Systems (Mac) 1 02-25-2005 12:48 PM
Strange NTFS issues ... PLEASE HELP! Doogz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-01-2003 10:43 AM
