Switching to new Mac...
I just bought a new G4 at eBay and I need to transfer everything - EVERYTHING - from my old Mac to the new one. Does anyone have any specific experience of problems or pitfalls with this - especially with Digi sound files? Hints and suggestions are welcome...
Also, can I simply remove my extra internal hard drive from the old Mac and install it in the new one or is there more to it than that? Thanks, D. |
Re: Switching to new Mac...
was your old machine a G4??
If so just use carbon copy cloner & Target disk mode. CCC is uncrippled shareware & is a far better tool than Apple's Dick Copy. hope this helps... |
erk!!! that should have said Disc copy obviously.
Freud would have something to sya baout that i'm sure. |
my typing has just gone totally to nonsense. Apologies.
the 'I want to preview my post' checkbox is there for a reason. i should use it. |
the simplest way is to connect the two via ethernet(using a cat4 CROSSOVER cable) set your tcpip connection to appletalk, set sharing priveleages (file-get info-sharing) and simple copy whatever you wish from the old to the new.
You can also install the old macs HDD to the new on as a slave drive. Pin to slave and follow these insteuctions. You don't need any special software to do either of these. |
Sorry I can't help D, but I just had to throw this in...
Neil, you need to leave that box unchecked. I am LMAO sitting here!! |
It's not rocket surgery |
I would suggest connecting them via firewire directly, then restart the new mac using target mode (hold down "T" during start up. This will turn the new mac into a firewire drive, and you can proceed to moving files over to the proper places.
tencentcat
Wiz
The underground is as fickle and shallow as the mainstream. |
glad i provided some amusement to folks...
Switching from Win to Mac | runner2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-20-2007 02:18 PM |
Switching from PC to Mac | Moller4/79 | Pro Tools M-Powered (Mac) | 1 | 04-02-2007 07:39 AM |
Switching from Mac to PC | Reb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-22-2005 10:41 AM |
switching from le to tdm | beatdigger | Pro Tools TDM Systems (Mac) | 3 | 04-11-2005 11:30 PM |
Switching from Mac to PC | harpdog123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-19-2001 09:58 AM |
