PCI riser ribbons / cards?
My GA-EX58-UD4 motherboard has 3 PCI slots, however only 2 are adjacent so If I were to add a third card to my HD2 system, the third slot would be too far for the Flex cable to reach it.
Here's a thought: has anybody successfully used one of these PCI riser ribbons? http://www.ebay.co.uk/itm/Flexible-P...-/180896140252 I have some space in my chassis so could probably squeeze in the third card closer to the first two. I'm only attaching the interface (HD Omni) to the core card so don't need to physically access the card. What do you guys think? |
Re: PCI riser ribbons / cards?
I think the riser component will probably work, but I'm not sure about the motherboard architecture - mainly the slot not being directly adjacent to the next one. TDM systems have always been finicky about which slot is the "first" slot that the core card goes in, and I have a feeling that this will probably be the case here as well. Unless someone else has already done it and can tell you it worked, all you can do is try it and see if it works.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
See Bob Nagy about a TDM Extender Cable. Its made to connect non Adjacent HD cards. You can reach him at bobnagy (at) AOL.com
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
How do I remove the mix riser brackets? | Bob Olhsson | Artist Series | 5 | 08-10-2012 08:54 AM |
node ribbons for pt mix tdm systems | LoganManorStudio | Pro Tools TDM Systems (Mac) | 2 | 02-03-2010 11:53 PM |
preamp for ribbons to mbox. | Pepo | Tips & Tricks | 10 | 07-25-2009 01:15 AM |
Oktava Ribbons ML52 | ISedlacek | Tips & Tricks | 2 | 06-25-2003 11:05 AM |
Building a drum riser...IDEAS PLEASE!! | s2n | General Discussion | 1 | 09-19-2001 06:21 AM |
