Old 06-22-2016, 02:47 PM
SWBoatman25 SWBoatman25 is offline
Default I am heaing clicks & pops in the Vocal Track..
Hello,
It seems I am getting little "bumps" or "clicks" in the vocals. Probably once or twice in every vocal line.
When I record a vocal track: in a sound booth with the peaks hitting around -14 to -10 db.
It is subtle and not a loud click but you can hear it in some words (like the sound of hitting a table or surface with your index finger).
There are no plug ins on the track.
I am pretty sure it is my equipment but I want to see if anyone has had this problem.
EQUIPMENT:
Pro Tools 12
Mac OS X El Capitan 10.11.4
Recording at Buffer Size: 32 samples
Playback at: 1024 samples
AUDIO INTERFACE: USB Scarlett 2i2
CORD: Mogami Gold XLR Cable
MIC: Behringer B‑1 Large‑Diaphragm Cardioid Condenser
HEADPHONES: Sony MDR-7507
Any tips or solutions would help.
THANK YOU!
Old 06-22-2016, 03:28 PM
Default Re: I am heaing clicks & pops in the Vocal Track..
32 samples... well that is easy, increase the buffer size until this goes away.
Use hardware monitoring in the 2i2 so you can run at larger buffer sizes without latency.
Make sure "ignore errors" is not checked. You want Pro Tools to let you know (crash) if it is having problems.
System fully optimized? Disk cache enabled (not "normal")? Recoding to a proper spec dedicated audio drive?
holler holler is offline
Hi, sounds like it's either the buffer size at 32 or some synching issue with your audio interface.
I would try setting the buffer size at 64 and see if it goes away if the latency feels OK at that buffer size, and if that doesn't help try setting it even higher and use low-latency monitoring. If none of that works it's probably a sync issue
Old 06-22-2016, 04:32 PM
Ah thank you for the responses!
I will give that a try at 64.
Old 06-22-2016, 04:33 PM
Thank you for the reply, what hardware monitoring are you talking about? Or do you mean just clicking the ignore errors and low latency options?
Thanks
Old 06-22-2016, 06:15 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
your interface ha the ability to provide a no latency monitoring solution while recording. you will have to consult the manual or tutorials to figure that out.
Thus making the recording monitoring experience much easier to record to when using high buffer setting in the software (to avoid the pops and clicks you referenced having)
if you are no longer recording and just monitoring and hearing the pops and clicks then try adjusting the buffer like people said previously.
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Why is my track count (with no pops or clicks) so low? GrievousAngel Windows 10 12-31-2011 04:21 PM
projectmix. pops & clicks on track after recording wreckthisplace Pro Tools M-Powered (Mac) 2 07-12-2006 11:30 AM
Remove mouth "clicks" from vocal track? tysonjm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-25-2005 12:56 PM
Clicks & Pops? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-31-2005 05:07 AM
Clicks and Pops on Bass track EricFuller General Discussion 2 11-05-2003 05:10 AM
