Old 10-09-2010, 07:59 AM
Jak Jak is offline
Default Accessing favourite soft synth presets...
I used to use PT 7, but jumped over to Logic 9. Now Im thinking of using both. I find that searching for sounds in soft synths is very time consuming, so one of the first things that I really liked about Logic was the feature of being able to save channel strip settings which I use to categorise my soft synth patches. I can toggle through my often used lead sounds, bass sounds, strings - whatever, simply by pressing control-command-arrow.
Does anyone know if PT 8 has a similar function where I can bank the soft synth presets? And then easily go through them?
I know my Axiom Pro has short cut keys which can go through the PT synths, but not third party soft synths.
Any help would be appreciated
Old 10-09-2010, 01:34 PM
Default Re: Accessing favourite soft synth presets...
DV Toolkit 2 supports Catalogs (DigiBase Pro).
Aaron Mulqueen - 001 HD Native
Old 10-10-2010, 10:00 AM
Jak Jak is offline
....I tried looking for this feature, but couldn't find anything. Could you kindly enlighten me?
Thanks
Old 10-11-2010, 06:24 AM
Jak Jak is offline
...anyone?
Soft synth vs Hard synth! Reason, Pro 52, V Statio Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-08-2003 10:51 AM
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? rtcstudio Pro Tools TDM Systems (Mac) 3 11-16-2002 07:57 PM
which soft synth? poul dehnhardt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-16-2002 09:15 AM
Best Soft Synth Please Dutchmuzik Pro Tools TDM Systems (Mac) 7 09-28-2001 11:15 PM
problem accessing plug in presets otto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-14-2001 05:46 PM
