Deleting fades
Hi
When I want to delete the fades - using the deletebutton - the audio is removed as well - leaving a blank space. When I use the command "delete fades" from the menu - the audio is still present. Why don't the delete button do the same thing? Hope you are able to help Thanks GS |
Re: Deleting fades
If you select just the fade before hitting the delete key.. then the fade (only) will be deleted.. if you select the audio region and the fade.. then the audio region and the fade will be deleted.
Rail
Re: Deleting fades
He means the audio underneath the fade. It's simple, delete means delete everything and delete fades means delete fades. got it?
Re: Deleting fades
No, what he means is that if any audio beyond the fade is highlighted, the audio and fade will be deleted. If only the area that is covered by a fade is highlighted then the audio stays, only the fade is deleted.
Double click within the fade and hit delete, no audio will be deleted, you dont have to use the menu, takes too long!!!!
IMDB |
Re: Deleting fades
Double click within the fade and hit delete, no audio will be deleted, you dont have to use the menu, takes too long!!!! [/QB][/QUOTE]
I never knew that. Thanks.
Steve Shepherd Extreme Mixing |
Re: Deleting fades
Hello. The way I'm used to deleteing fades is by selecting them with the grabber tool. Since I have the smart tool set most of the time, I just reach over with the grabber and select it. Then, I just delete. Another way the smart tools helps with fades is you have the trimmer when you get close to the edges of the fades. That way you can trim the fade in or out.
froyo |
Hotkey for deleting fades? | jschmidtiii | macOS | 2 | 04-02-2013 10:55 PM |
Fades prefs vs. Batch Fades (or beating a dead horse) | Starcrash | Post - Surround - Video | 2 | 09-23-2008 03:40 PM |
Deleting Fades in 6.7 | Hostage | Pro Tools TDM Systems (Mac) | 3 | 11-11-2004 08:28 PM |
fades on muted regions render active fades?! yikes | clarpark | Pro Tools TDM Systems (Mac) | 11 | 02-08-2004 04:49 PM |
"Deleting Unused Fades" | benderbro | Pro Tools TDM Systems (Mac) | 3 | 02-14-2003 10:59 AM |
