Old 07-26-2022, 06:03 AM
RichR RichR is offline
Default Plugin User Defaults not loading
Hi all.
I'm running PT 2020.6 on Mac 11.6.8 and I've noticed none of my plugins are loading the User defaults I have previously set. I have tried redoing them but they just won't load by default. Same for all plugins. Is this a pref or a weird setting?
Old 07-26-2022, 07:52 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Plugin User Defaults not loading
Hi, Not totally sure - are your presets saved in User-Documents-Pro Tools-Plugin Settings-Plugin?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-26-2022, 08:11 AM
Hi Chris. Yes they are
Old 07-26-2022, 08:25 AM
Update. I've discovered some plugins do load but not others. They're all in the right folder but PT won't load the User default on some. Lost....
Old 07-26-2022, 09:19 AM
The Weed's Avatar
The Weed The Weed is offline
Are they Waves plug-ins? Waves 14.0 has a "set as my default" and when I did that, it comes up as the right setting, but where it would show the User Setting in the top right, it says <factory default>.
Any Waves plug-in that already had a User Preset showing top right prior to updating to 14.0 still show correctly and load correctly. Only user presets done after updating to 14.0 don't.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-26-2022, 10:23 AM
Thanks! That's Waves sorted. Any idea how to get the SSL Native Channel Strip 2 to work?
Old 07-26-2022, 11:51 AM
Ben Jenssen's Avatar
I was thinking; let me see this can't be too hard. I use SSL plugins alot, and the channelstrip across the mix. I made shure of the settings, created a user preset in the root location, (edit: and selected 'Set as user default), but SSL ch.strip won't show up with anything other than 'factory default' preset. I'll be following this thread.
The waves central thing with a manufacturers plugin-manager storing stuff you don't know about, is more and more common. Acustica Audio is a grim example of this. I use DaisyDisk to quickly reveal unwanted stuff taking up disk space.
Edit: This last paragraph I actually meant to post in a different thread! I don't know how I got it here.
Old 07-27-2022, 01:57 AM
Turns out SSL have disabled this feature because of the plugin mixer software. The workaround is to overwrite the default with your own using the Default Preset display at the very bottom of the plugin. If you click on it you can then 'save as default' with your own settings. Boom....
Old 07-27-2022, 11:12 AM
Good work.
Thanks.
Old 09-26-2022, 03:21 AM
martthie_08 martthie_08 is offline
After upgrading to V14 I have had the same issue: Waves plugins will not default to the Pro Tools User setting. It is weird to me that the Waves plugin system (which I do not use) has priority over the plugin system within Pro Tools.
Now on to re-defining my default plugin settings on about 450 Waves plugins installed on my Mac, yay
Plug In User Defaults Saving Automation Selections Goombot Pro Tools 12 0 03-23-2016 02:13 PM
ProTools 10 to 11 and plugin settings/defaults WildHoney Pro Tools HDX & HD Native Systems (Mac) 5 01-14-2016 09:46 AM
Kontakt 5 not loading user pre sets keith l Pro Tools 9 0 03-10-2014 07:50 PM
How can I export my plugin mappings and defaults? usastra Pro Tools TDM Systems (Mac) 2 12-26-2010 12:47 PM
How to set Mp3 plugin defaults? jccrtv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-20-2006 09:00 PM
