AudioMedia II problems ...
Greetings all!
First my system specs: 7100/66AV, 128MBRamAdded, OS 8.5 My problem: I've installed an audiomedia II card and cannot get the card to work. I've tried most all the combos of DSI/DAE's and cannot even get the card to output alert sounds. The only version of PT I've tried is 3.4. PT3.4 runs great, but only in Powermix mode. When I check the hardware settings, the Audiomedia card doesn't show up as an option. I tried Deck 2.63 Demo w/ the recommended DAE/DSIs and got the "playback engine not initialized" error. I ran DigiTest 2.1 & 2.3 and got "card failed Test 50" returned (what does that mean, anyway?) Sooooo, I was hoping that someone within this forum could tell me a combination that should at least allow the card to output system alert sounds so I can be sure that this card is dead and move on to something else. thanks, kwigg22 |
Re: AudioMedia II problems ...
The NuBus Compatibility page lists DAE/DSI 3.1.1 for the AMII card which can be found here.
Unfortunately, Error 50 in DigiTest indicates a DSP Reset Failure which typically means a hardware problem on the card. Pro Tools 3.4 is a standalone (host) version of Pro Tools that doesn't use additional hardware, so it won't see the card.
• linkedin •
thanks for the reply ...
Is there anything I can do to salvage the card? kwigg22 |
We still provide repairs for this card. Contact us directly if you want to pursue this...
http://www.digidesign.com/aboutus/contact/
• linkedin •
upgrade from Audiomedia III to 001 causes problems | deadite4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-08-2006 03:27 PM |
Audiomedia III with K8V Deluxe (any problems?) | filete1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-11-2005 08:48 PM |
Hardware problems with Audiomedia III | Tomek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-30-2003 11:00 PM |
Audiomedia III problems..... | Pushpull76 | Tips & Tricks | 3 | 07-18-2002 12:18 AM |
audiomedia III problems list | Automation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-24-2002 08:04 PM |
