Old 10-11-2001, 03:13 PM
dj_czech dj_czech is offline
Default cpu / motherboard which are (most solid for digi) ?
Hello my digi friends?
Right now im running P3 600/scsi motherboard and im looking to
upgrade this week. (running out of cpu power) is the only problem i have , other wise my system is solid.
To do this i must buy a new cpu and scsi motherboard. I want the cpu to be at least 1.2 ghz and the motherboard must be scsi. Could someone suggest specific brands/models of cpu/motherboard/bios that work solid with DIGI , im trying to avoid complications and crazy trouble shooting.
Also what is the difference between Athlon and P3 (i would like to stay with P3 as it has prooved itself on my system).
Thank you in advance.
DJ.Czech
Vancouver
Canada [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
[email protected]
Old 10-11-2001, 09:57 PM
cutman707 cutman707 is offline
Default Re: cpu / motherboard which are (most solid for digi) ?
Right now I am running a P3933 with a asus cusl-2c mobo, and a adaptec 2906 scusi card with no probs right now. Loads of plugins and power and all that stuff-even though ive heard the autotune is a cpu hog. I got all my stuff from attic computers on broadway and ontario, not the best customer service, but if you know what your doing its really cheap.
cheers chris
Old 10-11-2001, 10:51 PM
APAULOS APAULOS is offline
I'm having the same problems with auto tune and some of the waves plug ins. I have a p3 750 but I'm about to upgrade to an AMD 14000 and a Gigabyte ga 7dx. Some of the users on the duc are really happy with this combo. Here's the deal, the thunder bird processors are seeing about twice the performance of the pentium 3 and 4 processors right now [img]images/icons/shocked.gif[/img] So if your gonna try to run more plug ins that's the way to go!
Old 10-12-2001, 02:19 PM
Mark_Knecht Mark_Knecht is offline
dj_czech,
I'm running a 1.2G Athlon on an Asus A7V133 motherboard, and then using a PCI SCSI adapter to talk to external SCSI devices. The machine is pretty loaded up, Ethernet, Sound Blaster, Digi, SCSI and is totally solid. I am using a good case with overrated power supplies and extra cooling. I can do 24+ tracks on the dave_c test.
There are some newer Asus motherboards that folks like, but so far getting way up in processor frequency may lead to stability problems, so check carefully.
Good luck,
Mark
Solid internal hard drive for Digi 001? InvalidInk Storage Subsystems 8 05-11-2010 03:52 PM
DIGi=solid...upgraded, now some questions... kindkind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-10-2007 01:43 PM
Mac Computer choices for solid Digi 002 performanc Not2Bu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-11-2005 06:46 PM
Digi Announces SOLID Synth for PT HD whtrabit Pro Tools TDM Systems (Mac) 14 04-27-2005 05:11 PM
SoundFuel Solid Synth for TDM Digi info please Dutchmuzik Pro Tools TDM Systems (Mac) 0 03-09-2005 06:07 PM
