"Type to Search" on track inserts, sends, and outputs not working 2023.9
I recently updated to Pro Tools 2023.9 on my Macbook Air (2020 M1 with the Sonoma 14.0 macOS) and I'm no longer able to "type to search" on track/aux inserts, sends, or outputs.
I used to be able to click on an insert of a track/aux and immediately start typing to find the plugin I want o use, but now I'm forced to manually click the "search" bar on the dropdown to find a plugin. While this is a very minor inconvenience, this has been slowing me down in recording sessions. I'm not sure if the new "sketch" feature has anything to do with this, but I searched through all of Pro Tool's preferences and haven't found anything new or relevant for this issue. Does anyone else also have this issue / has anyone found a solution for this? I'm running Pro Tools on my 2020 M1 Macbook Air with the Sonoma 14.0 macOS. |
Re: "Type to Search" on track inserts, sends, and outputs not working 2023.9
Hi, welcome to the community.
Sonoma is not yet supported.
Ok thank you. I'm going to downgrade for the time being
Pro Tools 2023.6 - Remove "Track Name" column from Memory locations window | ralphonz | Pro Tools | 10 | 09-24-2023 04:38 AM |
Field recorder guide track "select areas to search" doesn´t work | kwassen | Post - Surround - Video | 6 | 04-12-2017 11:53 PM |
"Search in Selected Areas" not working. Also- conforming different Bit Depths? | kylepyke | Post - Surround - Video | 2 | 08-29-2015 09:35 AM |
offline bounce from Send or Track outputs - track "freeze feature" | OliverH | Pro Tools 11 | 20 | 05-25-2014 04:45 PM |
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! | italianguitar | Eleven Rack | 15 | 03-20-2012 01:57 PM |
