Old 07-11-2023, 03:33 PM
Fritz Fritz is offline
Default punching in with Groove Cell
Is there a way to do this?
Laying down a live midi drum track with pads and I want to punch in.
"Do not fear mistakes. There are none."
Miles Davis
Old 07-11-2023, 04:42 PM
Default Re: punching in with Groove Cell
I added 3 mono audio tracks and used the multi-out of GC to assign to them.
I see it in GC, but don't hear audio.
The 3 audio tracks are in input.
It seems that GC is only capable of Main out.
Unless there is something I'm missing.
Miles Davis
Old 07-11-2023, 05:09 PM
though the mono input assigns are available, that ain't it.
Need stereo audio tracks and assign to the strip input as below.
Punch in audio and slide edits as per usual.
Miles Davis
Old 07-18-2023, 11:50 PM
skylar_battles skylar_battles is offline
Unrelated to the multi-output audio aspect of this, why don’t use just punch in on the midi to deal with it there? You don’t even have to use QuickPunch to do it although it can be helpful if using pre-roll.
Old 07-19-2023, 08:28 AM
maybe I'm missing something, but when I punch the midi, I get previous rec'd after the punch.
In other words I'm playing with mistakes.
Perhaps my config is wrong?
Miles Davis
Old 07-19-2023, 03:27 PM
It's pretty confusing because GrooveCell is stereo and even thought it's outputs within the plugin appear to be mono, you must use stereo AUX or audio tracks for multi-output routing.
See the attached routing :) You can also use one less track in this setup if you'd like and use the "main output." So the track with the plugin on it could be set up so that the audio output going is going to MON L/R and you can select the kick as going to the "main output" in GrooveCell.
To punch in, make sure MIDI merge is off and you can use the regular record mode or QuickPunch and it will work.
Old 07-19-2023, 03:35 PM
thanks. Toggled the midi merge and that has fixed the punch. Try again.
Miles Davis
I have No Presets in Groove Cell, just one drum kit justjohnmusic99 Virtual Instruments 19 08-23-2023 12:44 AM
Can't find Groove Cell (win) PerfectLabWing Pro Tools 12 2 06-29-2023 01:45 PM
Interesting feature with Groove Cell DonaldM Virtual Instruments 1 04-18-2023 11:12 AM
Groove Cell Not Working or Appearing Ornan2112 Pro Tools 2 03-02-2023 11:10 AM
other meters in Groove Cell? no 6/8? [SOLVED] AINSLIE Virtual Instruments 2 05-31-2022 08:37 AM
