Old 12-15-2016, 08:44 PM
sodastereo sodastereo is offline
Default Bounce volume
I´ve seen this problem all around the internet but can´t manage to fix it. When I bounce my mix (usually in 16 bit 44100 hz) I loose a LOT of volume, you may be thinking it´s a matter o mastering, but no. Even when I master it and try to get those extra db with the limiter and compressor I have the same problem.
I´ve even try to really crank up the limiter to get it real loud, to the point I couldn´t listen to it without hurting my ears, and when I bounce it, it looses all that volume.
Hope someone can help me
Old 12-16-2016, 05:13 AM
Default Re: Bounce volume
Check your routing in the session - maybe you're missing something. And rather than bounce try recording the session output to an audio track in the same session and see how that works. Never been a fan of bouncing as it's too easy for something to screw up.
Jack
QAPLA!
Old 12-16-2016, 06:41 PM
How are you listening to the bounced file? Could the volume drop be the fault of your playback program? My Bounced files always sound the same
Old 12-17-2016, 09:58 PM
waltz mastering's Avatar
waltz mastering waltz mastering is offline
You could try the above, then export and compare that to your bounce to see if there's an issue.
Unless something is not set up proper, the bounce should be what's coming through your master channel. gl
Tom W
www.waltzmastering.com
Low Volume After bounce fstarter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-29-2010 11:07 AM
Bounce volume it’s affected by the Wave volume in the PC? vegas4ever 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-23-2008 06:12 AM
MP3 Bounce Volume, Normalization and Reference Volume Daniel P Pro Tools TDM Systems (Win) 1 08-16-2007 10:50 AM
MP3 Bounce Volume too low, Normalization & Reference Volume Daniel P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-15-2007 12:11 PM
Low Volume after bounce pakobo7 Pro Tools M-Powered (Win) 1 08-07-2006 05:58 AM
