bounce & dither
I'd like to bounce a track (session in 48k, 24) to disk.
When the menu opens up I can select 44,1 16 bit and mp3...etc Does PT12 do any processing like dither? Is this a proper way to do it or can/must I add a dither plugin to the channel strip? Thanks
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Re: bounce & dither
For Exporting of files, PT will add dither. Search the manual for a chart. |
Re: bounce & dither
Yeah, rule of thumb is: Pro Tools dithers on export/import, does *NOT* dither on BTD conversions.
Honestly, it would be much simpler if they just gave the user the option to dither/not/noise-shaped on every import/export/btd/render operation, but that's not how it works.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Re: bounce & dither
Are you bouncing a single track or a full mix, and are you bouncing to 44.1/16/Mp3. You can sample rate convert within the bounce window or use a third party program to src. If you are bouncing to mp3, sometimes it's best to go right from 24 bit without dither. Mastered for Itunes does the aac conversion directly from 24bit at the native sample rate of the session, but if you do want to add dither to the bounce you would need to add it via plug-in on the track or master. _ Best WaltzMastering
Re: bounce & dither
Are you bouncing a single track or a full mix or master, and are you bouncing to 44.1/16/Mp3. You can sample rate convert within the bounce window or use a third party program to src. If you are bouncing to mp3, sometimes it's best to go right from 24 bit without dither. Mastered for Itunes does the aac conversion directly from 24bit at the native sample rate of the session, but if you do want to add dither to the bounce you would need to add it via plug-in on the track or master. _ Best WaltzMastering
dither and bounce | sickyboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-21-2005 06:07 PM |
bounce without dither | jwbyrd16 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-25-2002 10:43 AM |
Dither to 16 for MP3 bounce ??? | stoneinapond | Pro Tools TDM Systems (Mac) | 4 | 10-07-2002 12:53 AM |
Best way to bounce and dither to 16 bits | Anibal | Pro Tools TDM Systems (Mac) | 1 | 06-23-2001 03:43 PM |
dither and bounce to disk? | jonathan plum | Pro Tools TDM Systems (Mac) | 2 | 08-18-2000 08:27 AM |
