Sync'ing ProTools as slave with MTC
Hi All,
I'm a bit stuck with a synchronisation issue - I have and akai MPC4000 as the master clock source sending MTC and MMC to my pro tools setup via a RME UFX. I've got it half working in that the timing seems okay and it starts when i hit play/stop etc on the MPC but there are 2 major issues: - hitting play on the MPC makes Pro Tools start at bar 43126 (regardless of whether i start the mpc at sequence 1 or sequence 70) - if i have record mode engaged in Pro Tools (which is really the whole point of this exercise) hitting play on the MPC disengages it meaning that I can't record Any ideas as to what I should be looking for? I'm sure I've had it working before but i've tried a number of different settings with no luck |
Re: Sync'ing ProTools as slave with MTC
You should check to make sure the offset in protools is set to bar 1 and 00.00.00.00, my guess is that its not.
I would suggest dropping protools into record once a lockup between the two has been achieved especially as its the slave. Hope this helps.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Video Slave - Sync to PT | blizzard | Post - Surround - Video | 6 | 12-22-2013 01:28 PM |
Sync Slave Computer to Protools | blizzard | Pro Tools 9 | 1 | 02-09-2012 02:39 PM |
PT 7.2 doesn't see incoming MTC with Sync I/O, won't slave | Slappo | Pro Tools TDM Systems (Mac) | 4 | 04-04-2007 11:28 AM |
HD as 9pin slave w/o SYNC | cpi | Post - Surround - Video | 3 | 05-19-2003 11:27 AM |
Is it possible to slave or sync Mbox to Digi001 | Eddie K. wannabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-12-2002 11:31 AM |
