Problem using bounce procedure
When using bounce procedure it stops almost every time and send message: PTs ran out of CPU power.Try de-activating or removing Native plug-ins.(AAE-9173) From where to find thems? I also have long list UAs
plugins which I do not in use but when I put them into Trash Apollo did not work in record mode, only play - v8.0 MacBookPro late 2011 2,4Ghz,memory 16G,OSX 10.8.5 PT v11.2.2 |
Re: Problem using bounce procedure
I don't think it means that you have to remove the plugins from Protools entirely, maybe you are using too many plugins in your session, more than your computer can manage...
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
11.2 introduced these problems on Macs. Try updating to 11.3. Otherwise you may have to roll back to 11.1.3.
just seconding what cygnusx said. i upgraded to 11 when 11.2.x was new, and had to move back to 11.1.3. now 11.3.1 seems to have corrected this problem, though it still has its share of bugs.
Try increasing your playback buffer to the highest setting, Setup - playback engine buffer 1024. It will give your system more room to breath and try the bounce again.
Iv'e had this problem every once in a while. Adding Buffer was not helping at all.
I usually run at 1024 buffer size anyway. I am on a new Mac Pro and also 64 GB of RAm. It's a 64 bit system anyway. I usually just close Protools and either restart or just relaunch Protools and it seems to fix it, whatever it is. Does not happen too much. I also have some occasional CPU spikes which I do the same procedure and it usually fixes the problem. I have also noticed if you try to do too many quick maneuvers within the program and then bouncing to disk sometimes seems to create the problem. NO IDEA why, but it my trick seems to fix issues like buffer. I would also trash old prefs occasionally as well. I don't see this too much. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Are you by any chance running SansAmp in your session?
I have issues with Yosemite and pt 11.3.1 but bouncing is not one of them.
could be a plugin issue, perhaps try disabling all the plugins in the session and then bounce again if it bounces ok then the issue would point to plugins. |
Bounce Problem | MikeC | macOS | 7 | 12-13-2014 08:32 AM |
Help bounce problem | angthegreat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-29-2010 11:52 AM |
Problem bounce-ing..... | Ivar Thorolfsson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-05-2002 07:50 PM |
Bounce Problem 34 | AEW | Pro Tools TDM Systems (Mac) | 4 | 11-15-2001 12:42 AM |
PT 5.1 Bounce problem | mozart | Pro Tools TDM Systems (Mac) | 4 | 03-29-2001 04:14 PM |
