Using main analog outputs to master a recording
I have been using the 1/4" monitor outputs to powered monitors & bouncing sessions to my computer via fire wire. Now I would like to use the main analog outputs (or alt main outs)(or optical out) to master recordings on a Sony CDR-w33 CD recorder. The problem I'm having is I'm not getting any signal from either output. (no luck w/optical out either) Am I forgetting to turn something on to route the signal to these outputs. I have checked the user's guide and have not found any info on this. From what I've read it (the manual) assumes there is a -10 db line level signal coming from the output, there is not. How do I make this (any of these) output(s) active? Thanks in advance-Billy Bacon.
PS. the only active signal I'm getting(from the digirack) is from the monitor out & The headphones. Last edited by Billy Bacon; 09-28-2014 at 11:50 AM. |
Re: Using main analog outputs to master a recording
Exactly how are you "mastering". If its all with plugins, then the Sony is not required at all. Beyond that, mastering in Pro Tools isn't an efficient way to work. Sure, it CAN be done, but there are some other programs(for ITB mastering) that will work better, give you more options, more analysis tools, and allow for audio CD burning on the computer(Wavelab is my tool of choice for this, but Sound Forge, Sonic Foundry and CD Architect are options(there are likely others too, like SADIE).
Hi Dave,
Thanks for your feedback. I'm using a digibox 002. Up until recently I never had occasion to use the main outputs on the interface. I usually did a mix then gave it to someone else to master. The reason I want to use the Sony is that I used it for one song and was pleased with the results I got. It has a basic limiter & EQ that sound good. In this case I used the monitor output because it was the only output that had any signal coming out of it. I prefer using using the analog inputs over the optical (SPDIF) on the Sony because it has balance control (L/R) in case a mix is slightly louder in one channel in some spots. I have sonic on my computer but could only use it to make MP3's for some reason. I have a dozen or so songs I want to master onto one disc for pressing the problem is they were all recorded at different times in different studios so I want them to sound cohesive (like an album) same levels, general tone etc. I can't get any signal out of any of the outputs except for "monitor out" (& the headphone jack). It's got to be something simple but I don't know what, otherwise the interface has a problem in the output section. If that's the case then it was defective out of the box because I have never been able to get a signal from these outputs. In the mix window, on the I/O tab if I assign any path other than "1-2 stereo" there is no output (the meters stop jumping) |
How to use outputs 1-2 on Digi003 without getting main mix? | se.audio | Tips & Tricks | 10 | 12-21-2020 09:16 AM |
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 01:50 PM |
Nothing coming out of 11R Main Outputs | adjectives | Eleven Rack | 0 | 05-07-2012 01:01 PM |
Those who go direct, Main outputs or DI box? | Jd0g33 | Eleven Rack | 7 | 11-01-2011 08:27 PM |
Use DIGI-001 as main outputs for Mac? | birdFEEDER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-14-2003 12:02 AM |
