Old 05-14-2011, 04:15 PM
pistolhead pistolhead is offline
Default MIDI and Digi 003 hate each other
new problem... midi is working through the MOTU fast lane usb...
I record one midi track say Mini Grand piano VI.. it records and plays back fine...
then i go to record a 2nd midi track say strings with Expand 2 VI ... i record enable the track then when i push the record button on my digi 003 it triggers a sound on the virtual inst
i want to record on the 2nd track and it is just this sustained note that only stops when I un-arm the 2nd midi track.... ?????? anyone had this happen to them??????
its like the console is in midi mode but i never put it in that mode... and you can touch a fader or any button and it triggers sounds.... ????...... WTF????
Win7 on an Intel I7-870 8 gigs of ram Pro Tools 9 (9.0.2) and the latest drivers
Old 07-09-2023, 02:09 AM
jackmackdaddy jackmackdaddy is offline
Default Re: MIDI and Digi 003 hate each other
Did you ever find a solution to this?
Old 07-09-2023, 08:10 AM
Here are some thoughts from someone that has used the 003 with a fair amount of midi(on Windows):
#1-if the 003 buttons are triggering notes(which happened to me) then you should try another driver. In Device Manager, click on the firewire controller and update the driver. Then(I may not have the correct steps here as its been many years), don't choose the "automatic" option, and then select "Let me choose from a list". There should be 3 drivers available, so try either or both of the ones you are not currently using. FWIW, Avid recommends the "Legacy" driver, but the one that worked for me was the "TI Compliant" driver.
#2-there is a lot to learn with midi, so this may seem confusing(and it is), but if you set each instrument track to use its own midi channel, things work independently. It may also help to go into Midi Studio and fuss with things, BUT this is only if you have multiple controllers. In my setup, I had a Motif es8 and an old Ensoniq keyboard going in via a MOTU FastLane USB 2x2 and a Roland TD10 kit going in via the 003 midi input. I was able to record 3 separate Instrument tracks at the same time by setting the Motif to all midi channels EXCEPT 1 and 10. The Ensoniq was on channel 1(I couldn't figure out how to change that on the keyboard) and the Roland used midi channel 10(which is the "usual" for drums and percussion).
Hope this helps
I f$@#%g hate MIDI. aka Trying to get Structure Free to work WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-06-2008 10:48 AM
For those who hate the DIGI hardware dongle RUNRUN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-18-2004 08:24 AM
What do you HATE @ the Digi 002? a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 02-19-2004 02:56 PM
I HATE COMPUTERS! ..DIGI PLEASE ANSWER, OR SOMEONE PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-12-2002 07:38 PM
I love and... hate Digi! smcoptyltd Tips & Tricks 0 01-27-2001 05:44 PM
