Old 11-25-2009, 05:48 PM
nz nz is offline
Default MBP/FW Drive/002R
Hello,
I am getting ready to use my new Macbook along with my OWC FW drive (7200 rpm) and 002R to run backing tracks in a live concert situation.
Being that the Macbook Pro only has one Firewire port I want to be sure that I run all the devices in question in the correct series.
MBP>external FW drive>002r
or
MBP>002r>external FW drive
I tried having the drive sit in the middle of all the devices and the PTLE did not see the 002r. I put it after the 002 and got an error.
Also, the OWC is an On The Go 7200 version that is bus powered. I chose bus powered so that it is one less thing to go dead on stage if someone trips over a cord and pulls it out of the wall.
Can someone point me in the best direction for this setup?
Thanks!
nz
Old 11-25-2009, 10:02 PM
nst7 nst7 is offline
Default Re: MBP/FW Drive/002R
Your first example is correct, and what Digi recommends. Computer>Drive>002. Not sure about the other issues.
Old 11-26-2009, 04:39 AM
BScout BScout is offline
Bus powered won't work because the two devices draw too much off of the max from the firewire bus (even though the 002 is powered, it still draws some current, though little.) You need to power the drive.
Best firewire drive for mac digi 002r studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-26-2007 10:36 AM
PC CD Drive and -002R Playback Issue - Need Help JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-13-2006 02:28 AM
firewire drive for 002r and mac mini Help??? vahe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-17-2005 11:14 PM
Which order for FW Drive on 002R? macaholic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-14-2005 06:00 AM
002R and PB 1.5 Ghz hard drive question lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2004 04:31 PM
