Double tempo of MIDI file
Strange situation I got myself into with some MIDI files... I just imported a MIDI track into my session and realized that the person that tracked it recorded it at double the speed of my actual session (say 140 versus 70). So what is happening is that, obviously, the MIDI file is running double as fast when I import it into the master session. I know I can scale (or double) the value of the notes, but that leaves them in place where they are and I have to manually move each measure over to accommodate the longer note value. This is a pain. Is there a way to just double the default value of the MIDI file so that it plays in time without scaling? Might anyone have a suggestion how to get through this as quick and painless as possible? Thanks so much!!
nz |
Re: Double tempo of MIDI file
If you have a constant tempo (not a complex tempo map), make all tracks "sample-based", import the MIDI, take the tempo map from the MIDI, ensure the new MIDI track is set to Tick-based, use Scale Tempo from the Tempo Operations (or just adjust the tempo) to set the tempo back to the proper tempo, then convert the other tracks back to Tick-based as needed.
If you have a complex tempo map (actually I would do it this way regardless), I would import the MIDI into a new session, do the same stuff as above to adjust the tempo to the proper tempo and then export the MIDI and import it into the main session.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
Use the TCE Trim tool
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
I know that this is ancient, but crikey - it's perfect! even in 12.7!
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Exporting MIDI file without tempo map? | freeBase | MIDI | 1 | 12-07-2010 10:34 PM |
Using a MIDI file to export tempo changes | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-22-2010 05:24 AM |
PT8 - Make Double/Half Tempo of Midi File | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 02-16-2009 04:08 AM |
MIDI file import - tempo problems | jeremyroberts | Pro Tools TDM Systems (Mac) | 2 | 10-17-2005 06:35 AM |
MIDI parts, how to double or halve the tempo? | gonzolagonda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2005 03:21 PM |
