Old 11-04-2009, 08:41 PM
nz nz is offline
Default Adjusting tempo and it makes it out of sync!
Hello,
I have a quick question that is very frustrating to me.
I have a song with recorded regions in it. When I go to adjust the tempo earlier in the song, it shifts the whole grid over while leaving the audio regions in place. In other words, everything now is out time and out of sync.
All I want to do is adjust a tempo marking on the tempo track in a particular area and not have it affect any other measures but the ones that I am adjusting.
Am I missing something here?
Thanks!
nz
Old 11-04-2009, 08:54 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Adjusting tempo and it makes it out of sync!
U have to highlight a selection that u want to move & then go to change tempo & make sure ur only adjusting the selected time...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-07-2009, 05:15 AM
nz nz is offline
That's exactly what I do, but the problem is that the timeline after my selection moves to accommodate the tempo change in my certain measures and the audio stays on the time line where it is. The MIDI files move with the tempo/timeline adjustments, but the audio regions just stay put making everything out of time.
I know that I can adjust ticks/samples in the MIDI tracks to have the MIDI files stay put with the audio (samples) or shift with the time line (samples). I need to basically do the same with audio.
I'm not talking about elastic audio. Just having the files move with the tempo change placement on the time line.
Is there a way to have the audio files move with the time line when I adjust tempo?
This is very frustrating.
Thanks in advance for any help.
nz
Old 11-07-2009, 06:02 AM
flommer flommer is offline
I think you said it yourself.. Do the same thing with your audio tracks... Put them into ticks when you want them to move with changes to the tempo...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 11-07-2009, 10:16 AM
Pin the Tempo Ruler.
filosofem
Old 06-10-2010, 06:19 PM
Herbieoz Herbieoz is offline
Pin the tempo ruler? Can you please clarify.
Old 06-10-2010, 09:44 PM
Like a rubber band, you pin down one end whilst moving the other end.
Aaron Mulqueen - 001 HD Native
Old 06-10-2010, 09:48 PM
I started to say earlier that Filo's clarification may not be what u want (but I didn't say it)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 06-10-2010, 10:14 PM
What say you!
Old 06-10-2010, 10:16 PM
Originally Posted by filosofem View Post
What say you!
You say what?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Mbox 3 USB Makes Strange Crackle noise from the left output when adjusting the volume NatiTaub FireWire & USB Audio Interfaces (Mac) 0 04-06-2013 08:57 AM
Adjusting Tempo crownstatus Pro Tools M-Powered (Mac) 7 07-18-2009 05:31 PM
adjusting the tempo of an imported audio track erocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-02-2009 10:48 AM
Adjusting tempo with audio Adagio12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-09-2003 04:16 AM
adjusting bar/beat markers on tempo mapped session otto Tips & Tricks 0 08-30-2001 03:19 PM
