Importing multiple MIDI into a session
I am trying to compile a master session of a few other sessions. So in this, I need to import various MIDI files along with their tempo at various places on the timeline.
The problem is that I go to import a MIDI file and have it placed later in the timeline and no matter what option I choose for the import (beginning, selection, spot) it still blanks out the existing tempo information of anything before it in the timeline. If I try and use spot (which for me, means that the MIDI file will start along with it's tempo info at the spot my cursor is parked at) and select a measure that I want the file inserted at, it inserts the MIDI file at that point, but brings the other files before it along with it. Help! All I want to do is import MIDI files along my timeline session along with their tempos. This should be a very discrete thing to do with the MIDI file and they should not affect each other. Any thoughts?
nz |
Re: Importing multiple MIDI into a session
If you work backwards, last Tempo Map first, Copy the existing Tempo Map and import the next SMF and Paste after the last imported SMF. Then Copy all that Tempo Event data and import and paste the next.
filosofem |
Wow, not to be negative, but that sure sounds like a work around to something that should already exist and not be a problem to do.
Thanks so much, though...
nz |
importing midi from session to session help | clintusmaximus | macOS | 3 | 12-01-2011 03:27 PM |
Importing MIDI file from Logic gives multiple regions | JumpingInFire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-10-2010 07:01 PM |
Importing Multiple MIDI Files with Different Tempo Changes | gdugan | MIDI | 5 | 04-19-2008 01:49 PM |
Importing multiple midi files into a pro tools session | deryanagle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-19-2008 07:22 PM |
Importing midi from one session to another | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2006 02:29 PM |
