003 DI inputs
Hello,
I just wanted to clarify something regarding the 003R's DI inputs. I have been exclusively using the 5-8 inputs as I only want to use my really high quality preamps that I have. I don't want to "double preamp" my signal by going from my external pres into inputs 1-4. If I use the DI 1-4 inputs is that the sonic equivalent of using the line inputs of 5-8? I haven't used them yet in DI mode. I would take it the input trim on the front would be disabled? This would be great news as then I can have 8 channels of external preamp instead of just 4. Any help on this would be much appreciated. Thanks!
nz |
Re: 003 DI inputs
My understanding is that the DI input is just a 18db pad. It still goes through the preamp... I think if the gain knobs still work, then it is not bypassing the pre
However, if you have preamp with some serious mojo, it's sound will still shine through.. Just try it.. Let us know what you find.. I don't have the nice preamps to test this myself
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: 003 DI inputs
No, a DI (Direct Injection/Instrument) is to convert a the unbalanced signal to line level before it goes to the pre-amp. The voltage is different, thus the invention of DI boxes, in this case, Digi built one into the 003, but you have to turn it on when you use an unbalanced Tip Ring 1/4" cable from an instrument. Otherwise, w/out the DI/ you'd be converting a balanced signal (XLR) to line level. After the input (pre) all signals are line level.
Having said that, if your expensive outboard pre's have Line Level outputs, then you can run into the DI of the 003. I think to some extent you would need to "pad" your signal as it may get pretty hot. Unfortunately, the pre's on the 003 don't have a pad as found on more expensive consoles. A pad would be needed in addition to the level pots. While I'm on the subject, the 003 does have a HP Filter, but I don't tend to use it... I'm sure it's documented somewhere but I'd like to know where the cut off is for the filter... I hate just pressing a button that says "HPF"... I'd like to know where it's starting it's cut. But If I had some very expensive outboard pre's that weren't light pipe, I'd probably use the 5-8 inputs as they do have pads (button's beside the inputs). The other thing to consider is a Pre-Sonis Light pipe digital pre. This will give you an additional 8 inputs to the 8 that are already on the 003.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Re: 003 DI inputs
From the "Getting Started" Guide:
If your external pres have adjustable output range, you may want to set them to -10 first. +4 may be too hot.. Since you want to use external pre amps, then this will not be as ideal of a connection as the "pure" line inputs 5-8. But it may not be a deal breaker.. Try it.. Let us know if you can hear the difference..
Re: 003 DI inputs
High-end preamps through inputs 1-4 still sound high-end. I've tried numerous times. You cannot bypass the pres, but regardless of that, leave them at the minimum, and use your outboard pres.
TD
my blog:Tamas Dragon |
Re: 003 DI inputs
Thanks for all the help everybody. I really appreciate it.
nz |
Using Eleven Rack inputs like POD X3 inputs | dayslypper | Eleven Rack | 1 | 10-09-2010 09:15 PM |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
inputs | ardiemizzou | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2006 09:19 AM |
001 vs. 03D inputs | Alvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-13-2002 07:16 AM |
