Old 07-31-2016, 03:16 AM
danyg danyg is offline
Default bounce & dither
I'd like to bounce a track (session in 48k, 24) to disk.
When the menu opens up I can select 44,1 16 bit and mp3...etc
Does PT12 do any processing like dither? Is this a proper way to do it or can/must I add a dither plugin to the channel strip?
Thanks
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 07-31-2016, 04:47 AM
Drew Mazurek's Avatar
Default Re: bounce & dither
Thanks
Not during a bounce, you need to put a dither plug on the master fader.
For Exporting of files, PT will add dither. Search the manual for a chart.
www.drewmazurek.com
Old 07-31-2016, 08:23 AM
Yeah, rule of thumb is: Pro Tools dithers on export/import, does *NOT* dither on BTD conversions.
Honestly, it would be much simpler if they just gave the user the option to dither/not/noise-shaped on every import/export/btd/render operation, but that's not how it works.
http://www.richbreen.com
Old 08-01-2016, 06:48 AM
waltz mastering's Avatar
waltz mastering waltz mastering is offline
Thanks
Are you bouncing a single track or a full mix, and are you bouncing to 44.1/16/Mp3. You can sample rate convert within the bounce window or use a third party program to src. If you are bouncing to mp3, sometimes it's best to go right from 24 bit without dither. Mastered for Itunes does the aac conversion directly from 24bit at the native sample rate of the session, but if you do want to add dither to the bounce you would need to add it via plug-in on the track or master. _ Best WaltzMastering
Tom W
www.waltzmastering.com
Old 08-01-2016, 06:55 AM
Thanks
Are you bouncing a single track or a full mix or master, and are you bouncing to 44.1/16/Mp3. You can sample rate convert within the bounce window or use a third party program to src. If you are bouncing to mp3, sometimes it's best to go right from 24 bit without dither. Mastered for Itunes does the aac conversion directly from 24bit at the native sample rate of the session, but if you do want to add dither to the bounce you would need to add it via plug-in on the track or master. _ Best WaltzMastering
Tom W
dither and bounce sickyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-21-2005 06:07 PM
bounce without dither jwbyrd16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-25-2002 10:43 AM
Dither to 16 for MP3 bounce ??? stoneinapond Pro Tools TDM Systems (Mac) 4 10-07-2002 12:53 AM
Best way to bounce and dither to 16 bits Anibal Pro Tools TDM Systems (Mac) 1 06-23-2001 03:43 PM
dither and bounce to disk? jonathan plum Pro Tools TDM Systems (Mac) 2 08-18-2000 08:27 AM
