Adjusting tempo and it makes it out of sync!
Hello,
I have a quick question that is very frustrating to me. I have a song with recorded regions in it. When I go to adjust the tempo earlier in the song, it shifts the whole grid over while leaving the audio regions in place. In other words, everything now is out time and out of sync. All I want to do is adjust a tempo marking on the tempo track in a particular area and not have it affect any other measures but the ones that I am adjusting. Am I missing something here? Thanks!
nz |
Re: Adjusting tempo and it makes it out of sync!
U have to highlight a selection that u want to move & then go to change tempo & make sure ur only adjusting the selected time...
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
That's exactly what I do, but the problem is that the timeline after my selection moves to accommodate the tempo change in my certain measures and the audio stays on the time line where it is. The MIDI files move with the tempo/timeline adjustments, but the audio regions just stay put making everything out of time.
I know that I can adjust ticks/samples in the MIDI tracks to have the MIDI files stay put with the audio (samples) or shift with the time line (samples). I need to basically do the same with audio. I'm not talking about elastic audio. Just having the files move with the tempo change placement on the time line. Is there a way to have the audio files move with the time line when I adjust tempo? This is very frustrating. Thanks in advance for any help.
nz |
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
filosofem |
Pin the tempo ruler? Can you please clarify.
Like a rubber band, you pin down one end whilst moving the other end.
Aaron Mulqueen - 001 HD Native |
I started to say earlier that Filo's clarification may not be what u want (but I didn't say it)
What say you!
Mbox 3 USB Makes Strange Crackle noise from the left output when adjusting the volume | NatiTaub | FireWire & USB Audio Interfaces (Mac) | 0 | 04-06-2013 08:57 AM |
Adjusting Tempo | crownstatus | Pro Tools M-Powered (Mac) | 7 | 07-18-2009 05:31 PM |
adjusting the tempo of an imported audio track | erocker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-02-2009 10:48 AM |
Adjusting tempo with audio | Adagio12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-09-2003 04:16 AM |
adjusting bar/beat markers on tempo mapped session | otto | Tips & Tricks | 0 | 08-30-2001 03:19 PM |
