Old 11-15-2022, 05:56 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default bounces not really 32 bit?
So I've now had 3 tracks rejected by rather large labels as "44/16 in a 44/32 wrapper". So they can't/won't accept them. On my end, The bounces from Pro Tools are bounced at 32. When I do "get info" on the Mac, it says "44k/32bit".
I've been doing this for 20+ years. first problems I've had. But it's with multiple mixes.
Brian
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 11-15-2022, 06:03 PM
Top Jimmy's Avatar
Are you applying 16-bit dither anywhere? Dither will remove the lower bits.
Try Stillwell’s free Bitter bit scope and see if you can find where in the signal path this is happening.
James Cadwallader
Old 11-15-2022, 06:20 PM
Default Re: bounces not really 32 bit?
I mean its an 80 track session. I don't know if any of the plugins are applying dither unwantedly. I'll look up that program. Any other help or experience would be helpful
b
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 11-15-2022, 07:03 PM
Thanks for the Bitter Tip man! So I learned something new. may not save my job. but I learned something new.
I use Slate FGX a lot as a final plugin. And if the dither is on, no matter what you say in Pro Tools, it exports the file at that bit rate. So in Slate, if you set dither to 16 (or maybe it defaults there I don't know why it was set there), even I bounce at 32, the labels sniff it out and it gets rejected.
I then set FGX to 24, and Bitter showed 24. Then I turned FGX dither off, and voila, it goes to 32.
I then pulled the 16 bit and the 32 bit mix into PT, and flipped phase on one. Everything nulls except some lead vocal fx. so I have no idea what that means. except they sound the same to me.
T-Racks and Sony Limiter did not have this issue. If you can call it that. I havent pondered dither in many years. Just passing this on to anyone else who might be in my shoes at some point.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 11-15-2022, 07:04 PM
Eric Lambert's Avatar
b
I think he's referring to the master fader. Is there anything which the whole mix is running through which might be dithering? Those are the plugins I'd be looking at.
Old 11-15-2022, 07:46 PM
Tweakhead Tweakhead is offline
snip . . . Everything nulls except some lead vocal fx. so I have no idea what that means. except they sound the same to me.
possible explanation: if you printed the mixes as separate passes, any kind of modulation on reverbs or delays etc might not necessarily start on the same cycle if they're not tempo-locked.
Old 11-15-2022, 09:25 PM
re:verbs... thats my thought. they aren't the same every time so they wouldn't null.
Mentally, I am glad they sound the same. But what stress and confusion! Over non essential parts of the wave.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 11-16-2022, 04:58 AM
dominicperry dominicperry is online now
This is a BS requirement for any music which is reasonably compressed - rock, pop, EDM, country, rap. I can see the desire for a 24 bit file for some classical music with wider dynamic range, but no one is ever going to hear the difference between a dithered 16 bit file and a 32 bit file on pop etc.
Anyway, the above is a bit of an aside, but no surprise you can't hear the difference.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 11-16-2022, 05:21 PM
Top Jimmy's Avatar
James Cadwallader
Old 11-17-2022, 01:04 PM
It's not about sonics, it's about standardization. They request these specs across the board and a computer checks upon upload to see if the file qualifies. No one is sitting and listening and judging which format is necessary. I've worked with the quality control department at these places and it's largely automated.
That's out of our control; what's being asked here is why the file is being considered 16/44.
11.0.2 TC/E - odd bounces talkingbooks Pro Tools 11 14 05-07-2014 09:05 AM
ADC and bounces EricWillhelm Pro Tools 10 3 12-20-2013 09:44 AM
7.3 on 10.4.9 bounces once, then nothing DjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-18-2007 07:53 AM
5.1 bounces PPRECS Pro Tools TDM Systems (Mac) 1 04-07-2007 01:14 AM
PTF bounces lanhet Digidesign Hardware & Software 4 04-30-2001 10:26 AM
