Nipinpg down a short clip in volume
HI Guys
I just realised whilst i was working on a commercial that i didnt know how to do this. I have a Voice track that is suffering from a very short (about 1/4 second) increse in volume of about +2 db. I dont want to turn down everything else for the sake of this transient, and cant really get it on automation as its too short and i clip the incoming or outgoing audio too. Is there a way of cutting the offending audio and applying a -2db level change to only the isolated portion? My solution was to move the bit to a new track as it was the best i could come up with at the time, but now i could do with the real solutions. Cheers Peter |
Re: Nipinpg down a short clip in volume
Precisely select the offending part, then use the Audiosuite Gain plugin.
Quad 2.5 G5, 4.5G RAM |
HI teleplayer
I just tried that. There didnt appear to be an Audiosuite Gain plug in available that would obviously do that. I applied a compressor plug in with the threshold to inactive and dropped the gain that way but ofcourse it needed to be rendered. Was this what you meant? Is there no way of typing the value directly to the clip of audio like in Final cut pro etc, or highlighting the clip and have the faders positions set for only the duration of the portion? peter |
There should be a Gain plugin in your Audiosuite menu.
you can select the offending area and switch to the volume automation playlist, then use the trim tool to adjust the automation value for just the selected area. Depending on the nature of the audio, you may need to do some tweaking of the ramps to and from the new level, but that's easy enough.
You could also use the audiosuite plug-in route and render the new level. Go ahead and select a little more than you need to process so that you can trim and adjust the edits and crossfade to make it seamless. I actually prefer this method to automation, unless you already have volume automation on that track. Good luck. |
Thanks guys
Ive found the gain plugin now. It was a bit hidden. Seems to work well. thanks very much peter |
Clip gain or Volume Automation for S's on Vicals | SpinningDisk | Tips & Tricks | 12 | 12-20-2013 06:52 AM |
change clip volume for a entire group | Talisker | Pro Tools 10 | 2 | 03-13-2013 08:33 AM |
Clip Gain and volume autiomation | bonzerboy | Pro Tools 10 | 3 | 05-07-2012 11:52 AM |
Clip-gain post-EQ but pre-volume-graph? | Frank Kruse | Post - Surround - Video | 11 | 11-29-2011 10:18 AM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
