Video Slave 3 - How Stable?
Hello,
I downloaded the trial of Video Slave 3 to find a more stable video engine than the AVE, but after using it all day i've had a dozen or so hard 'Video Slave 3 Quit Unexpectedly' crashes. I'm not sure whether its my system, or the software is incompatible with my OS, or I just don't have it set up right. Any advice or optimisation notes would be helpful. - T
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Re: Video Slave 3 - How Stable?
Trent, just to make sure ...
When using the trial version, the software automatically quits every 30 minutes as a standard behavior. Could this be what you're experiencing? Or does VS really quit with an error message? (I've never had my VS crash as of yet so I'm a bit surprised.) Did you copy the app itself to the desktop or Applications folder? You're not running it from the DMG archive are you? Curious ..
Marcel Risberg Production sound and audio post - ljuddesign.se Enthusiastically sharing knowledge and experience at Stockholm Film School. 🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni 🎚 EuControl x.x.x · Artist Control · Mix · Control App 🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019) 📺 Separate video playback machine 🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free |
Hey Marcel,
haha Yeah that's not what I was experiencing, sometimes I can be a bit dense but this is not one of those times. Yep the application really is hard quitting; 'Video Slave 3 Quit Unexpectedly - Report. Ignore. Relaunch.' It will do it maybe four or five times within a half hour period. Yes, i'm also running it from the Applications folder, i've tried removing it including it's .log, .plist, and cache files then reinstalling it but no luck. After using it for a couple of days and ignoring the crashes; i'm 50% impressed. Using it as an alternative to AVE; VS3 doesn't playback at half speed, it lags on the first 5 frames after hitting playback, you can't resize the window beyond 50% of the original video size, and video freezes when you hit the full screen (on an ultra wide monitor). But. No more AVE hangs.
Actually there is a way to make it loop. Look on the knowledgebase for that answer on their website. I have yet to try it as I have been really busy since I got it up and running after a studio upgrade. Haven't had too much time to "play" yet. Yes, the lag time on startup is annoying. I am using an Aja Kona 3G on a separate video computer. There seems to be no way to save the display offset in milliseconds. Something I am going to write to Flo about who is pretty responsive about suggestions and help. Another quirk is not being able to "close" a session and bring up a new window. You have to just create a new playlist. If you have to set an offset as I do for your monitor setup, then you need to take the offset off in order to do frame by frame nudging. Not good for placing Fx or matching Dx/ADR. So far my workaround is to have the video handy in the actual session as well. I like it, but I don't love it as of now. I think Flo will continue to make improvements however.
PT 12.7 HDX 2/Mac OS 10.10.5 2012 Mac Pro 3.46GHZ/64GB RAM |
Yes, but it's not as simple as putting PT in Loop Playback or record, VS3 has to control Pro Tools and they advise sync can drift overtime. If Pro Tools sent MTC correctly this wouldn't be an issue! I was over simplifying, as getting it to loop isn't that easy.
of Post Sound Mixing. Everything else is an added extra. Get the basics right and I'm interested. Make it faster, better and repeatable and you have a winner. Compromise the essentials and I'm not interested.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
All I can say is give it a try, especially those who have issues with video in Pro Tools. |
I can not confirm this.
F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
WTB: Video Slave 3 Licence | TrentWilliams | Buy & Sell | 0 | 03-10-2017 09:33 PM |
Video Slave - Sync to PT | blizzard | Post - Surround - Video | 6 | 12-22-2013 01:28 PM |
Hosting video outside of Pro Tools as a slave | NGati016 | Pro Tools 9 | 0 | 10-17-2012 08:42 AM |
What video cards are you using that are stable with XP and 7 and PT | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 03-10-2010 04:56 AM |
442 & 888 audio interfaces & video slave | Ray Goto | General Discussion | 0 | 07-17-1998 08:24 AM |
