Pro-tools 10, a Pro-fire, and the mac-Pro...
I have recently purchased a macbook pro with the Mountain Lion OS, Quad-core intel i7 processor speed 2.6, and 8 GB memory. I am looking to put together Protools recording for my studio. I will be recording and mixing local bands. i am looking at protools 10 and M Profire 2626 fire wire and a small control pad to start with.
will Protools 10, the Profire 2626 and my laptop work together for this? and any experiences that people have had with a smiler set up? |
Yes, but you need to pay attention to all the requirements-go read that doc carefully. Especially disk, you should have an additional 'audio spec' drive for recording to. TO be conservative I would look for a Firewire 800 drive (must be 7200 rpm and Oxford chipset and not a "green" drive that spins down or does power management silliness, see drives from OWC, Glyph or G-Tech) and connect that to you MacBook via an Apple Thunderbolt to FireWire 800 adapter and use the built in FireWire 800 port for the 2626 so you don't have chain the interface and disk on the same Firewire bus. You could also look at thunderbolt disk but do not use hardware or software RAID. USB3 drives may work but historically USB has been problematic on the Mac and not recommended. SSD drives may work, Avid has recently just officially blessed them, but I am scheptical of how they did this, given this applies to all SSD drives and there are some really junk drives out there. I wonder how much testing and qualification Avid really did. Darryl |
Macbook white Profire2626 PT10.3 Lion here. Works fine! 16 tracks recording simultaniously with no problems at all. Can't tell you how it works with 10.8...
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Pro-tools 10, a Pro-fire, and the mac-Pro...
i put pro tools 10 on my mac book pro its working just fine, so far with no extra memory. we will see how much it can really handle here soon.
I'm running a similar setup but not getting sound from my profire 2626. From the Mac I'm going FireWire 800 to 400 into the profire. Then 400 to 400 from the profire to my external drive. I'm running PT10 on the latest update of mountain lion OS X 10.8.2
Any thoughts on how I can fix? Thanks. Matt |
pro fire 2626 and pro tools 9 le | billpeters1967 | Pro Tools M-Powered (Mac) | 1 | 06-30-2011 08:39 AM |
PRO TOOLS 8.03 AND WINDOWS 7 (64 bit) IS ON FIRE | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 12-30-2009 04:05 PM |
Pro Tools can't find my Fire wire box | LordCrotchpants | Pro Tools M-Powered (Win) | 1 | 11-11-2006 06:26 PM |
Pro Tools 7.0 Won't Recognize 410 Fire Wire? | UncleJerry | Pro Tools M-Powered (Mac) | 1 | 02-21-2006 08:35 AM |
Fire Wire Problem with Pro Tools 6.2.2 PLEASE HELP | wreckthisplace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-11-2003 11:35 AM |
