002 Won\'t Fire Up HELP
It's been in a bit of a cold but dry storagfe area for sometime and now when I power it up
I see nothing but the "mute" button for the monitor out illumunated??? This was an expensive piece of gear and IT BETTER NOT BE DEAD!!! Anyone have any insight? I'm only tring to operate it in stand alone mode, but none of the button illicit a response. HELP |
Re: 002 Won\'t Fire Up HELP
bump
do a search for "Power Harness" issues -sounds like that's your problem- before that though, try changing your FireWire cable.
So. a search should give you all the info -also, try contacting your dealer.
www.kitestudio.co.uk Mac Pro Snow Leopard 003 & Midas Venice desk Mindprint DTC Soundelux U99 Drawmer M-Clock |
there is little if any information on the "power harness" problem when I did a total forum search.
Sam Ash in NYC was my dealer, but that was like 3 years ago. What's the fix for the problem - and how do I diagnose it? |
The failure of the 002 to initialize properly is either caused by the power harness or power supply. There can be many other causes, but these are by far the most common. Call Digi and they'll send you a replacement power harness and installation instructions to fix it. Mine died the first week I had it. There are some here who have had the problem more than once. I don't think Digi will charge you but you'll have to check.
Good Luck.
Mac Pro 5.1 12Core 48GB RAM, 4 Internal Drives Mackie Onyx 1640i, PTLE 12.7 w/MPTK2, OSX Yosemite. MacBookPro 13" 2.26GHz 8GB RAM, OSX El Capitan w/MOTU Ultralite Mk3. |
Thanks for the responses, I did a search on the web and it brought up some old posts that I couldn't
access through a direct search here. Anyway, I opened up the bottom cover pressed on all the ribbon connectors attached to the power transformer and wha lah it works. This is really frustrating considering how much this thing costs. A loose or dirty connection rendering a 2k piece of prosumer gear useless? |
HI,
glad you got i t fixed, but read through this post of mine, just in case problem re-appears !!! http://duc.digidesign.com/showflat.p...r=763640&Forum [color:blue] [/color] sorry for the link --"URL" section of Instant UBB Code is not working for some reason !!!
Echo Fire | Mekanix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-18-2003 03:08 AM |
HELP - studio fire | arepechu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2002 10:29 AM |
fire wire? | DanXx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2000 10:22 AM |
888 on fire | trombino | Pro Tools TDM Systems (Mac) | 5 | 02-16-2000 05:11 PM |
