need a bit of help with pro tools HD?
Hi I want to use Logic 8 on my G5 as the front end and use TDM plugins, what exactly would i need?
The HD interface and an Accel card for my mac? or do u need the Core card and accel card? Ive ben told a couple of different things by differnt people. help would be much appriciated Thanks |
Re: need a bit of help with pro tools HD?
just a core card
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Depends on which plug-ins you want to use as some will only run on the accel dsp cards in which case you would need both and to be honest you wouldn't get a huge amount of dsp power just running a core card. My advice would be to stay away from TDM plug-ins unless you need them for tracking purposes or are going to move over to pro-tools and spend the money instead on well coded plug-ins like the native Waves stuff and the most powerful G5 you can lay your hands on.
Hope this helps a bit.. |
