Pro Tools First - AAE -6117 Error
Hi everyone,
I have an AudioBox 1818VSL interface by PreSonus which I use to record audio with StudioOne. I recently installed Pro Tools First and receive an AAE -6117 error. I have the latest driver installed for my interface and have reinstalled it a number of times. I have pressed and held the 'n' key on startup but nothing happens. My PC has an AMD A6-6420K CPU if that helps. I would like to get Pro Tools First working before I buy Pro Tools 12. How can I fix this error? I should also mention that it works fine on my brother's PC which has an Intel i5 Core CPU. Thanks in advance. |
Re: Pro Tools First - AAE -6117 Error
That error code is a "Device not found" error. So you have tried the N key and what happened then? Inside PT have you set your interface to VSL and restarted your computer?
What happens of you open PT with no interface, just ASIO4ALL as a sound device?
Nothing happens when I pressed 'n'. It tries to load as normal and gives me the -6117 error.
I can't set the interface in Pro Tools. It loads up and gives me the error. I can't go anywhere inside Pro Tools. |
With no interface it does the same thing.
We would need a Sandra report to sort this out.
The full free version and can be downloaded here: http://www.sisoftware.eu/download-buy/
Ok, I'll do that later on today.
Below is the Sandra Report for the PC I am trying to run Pro Tools First on.
-------------------------------------------------------------------------- Computer Model : OEM Chassis : Desktop Mainboard : ASRock FM2A88X Extreme4+ BIOS : AMI (OEM) P3.00 02/05/2016 Total Memory : 15GB DIMM DDR3 Processors Processor : AMD A6-6420K APU with Radeon(tm) HD Graphics (2T 4.19GHz, 1.5GHz IMC/1.6GHz, 1MB L2) Socket/Slot : FM2 (PGA904) Chipset Memory Controller : AMD F15 (Trinity) APU HT Hub 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-14900CL9-4GBXL 4GB DIMM DDR3 PC3-14900U DDR3-1866 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-14900CL9-4GBXL 4GB DIMM DDR3 PC3-14900U DDR3-1866 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-14900CL9-4GBXL 4GB DIMM DDR3 PC3-14900U DDR3-1866 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-14900CL9-4GBXL 4GB DIMM DDR3 PC3-14900U DDR3-1866 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : ACR K242HL (1920x1080, 24.0") Video Adapter : AMD Radeon HD 8470D (3CU 192SP SM5.0 800MHz, 1GB DDR3 1.6GHz/1.87GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : AMD Radeon HD 8470D (192SP 3C 800MHz, 1GB DDR3 1.6GHz/1.87GHz 128-bit, Integrated Graphics) Compute Shader Processor : AMD Radeon HD 8470D (192SP 3C 800MHz, 1GB DDR3 1.6GHz/1.87GHz 128-bit, Integrated Graphics) OpenGL Processor : AMD Radeon HD 8470D (192SP 3C 800MHz, 1GB DDR3 1.6GHz/1.87GHz 128-bit, Integrated Graphics) Storage Devices SanDisk SDSSDHII120G (120GB, SATA600, 2.5", SSD) : 112GB (C:) WDC WD1003FZEX-00RLFA0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:) HL-DT-ST DVDRAM GH24NSC0 (SATA150, DVD+-RW, CD-RW, 512kB Cache) : N/A (D:) Disk (, DVD+-R, CD-R, 512kB Cache) : N/A (F:) Logical Storage Devices System Reserved : 100MB (NTFS, 4kB) @ SanDisk SDSSDHII120G (120GB, SATA600, 2.5", SSD) 1TB Storage (E:) : 932GB (NTFS, 4kB) @ WDC WD1003FZEX-00RLFA0 (1TB, SATA600, 3.5", 7200rpm) SSD (C:) : 112GB (NTFS, 4kB) @ SanDisk SDSSDHII120G (120GB, SATA600, 2.5", SSD) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH24NSC0 (SATA150, DVD+-RW, CD-RW, 512kB Cache) Optical Drive (F:) : N/A @ Disk (, DVD+-R, CD-R, 512kB Cache) Peripherals LPC Hub Controller 1 : ASRock Hudson LPC Bridge Audio Device : ASRock Trinity HDMI Audio Controller Audio Codec : ATI (AMD) HDMI Audio Audio Device : ASRock Hudson Azalia Controller Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Disk Controller : ASRock Hudson SATA Controller [AHCI mode] Disk Controller : ASRock Hudson IDE Controller USB Controller 1 : ASRock FCH USB XHCI Controller USB Controller 2 : ASRock FCH USB XHCI Controller USB Controller 3 : ASRock Hudson USB OHCI Controller USB Controller 4 : ASRock Hudson USB EHCI Controller USB Controller 5 : ASRock Hudson USB OHCI Controller USB Controller 6 : ASRock Hudson USB EHCI Controller USB Controller 7 : ASRock Hudson USB OHCI Controller USB Controller 8 : ASRock EJ188/EJ198 USB 3.0 Host Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 6500 E709n Series (1200x1200, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : VirtualBox Host-Only Ethernet Adapter (Ethernet, 1Gbps) Network Adapter : Qualcomm Atheros AR8171/8175 PCI-E Gigabit Ethernet Controller (NDIS 6.20) #2 (Ethernet) Wireless Adapter : TP-LINK 300Mbps Wireless N Adapter #2 (802.11g (ERP), AES-CCMP, 54Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Is there anything wrong with my current setup in regards to running Pro Tools First?
Well i am a bit stumped why it says 15GB Ram and it is 4x4 GB sticks.
Other wise I can't really see a showstopper with that report. Have you tried to take out two sticks and see of one of then are broken!?
No I haven't tried that yet. I will though.
I was a bit surprised when it said 15GB as well. Windows takes some memory for itself doesn't it? Is my CPU chipset compatible with it? |
Pro Tools First error -6117 | Olafthebard | Pro Tools | Intro Discussion | 26 | 05-07-2017 12:08 PM |
Pro Tools First Error 6117 | Muse0216 | Getting Started | 2 | 03-02-2016 08:56 AM |
Unable to run Pro Tools First due to Error AAE -6117 | zaltobass | Windows | 1 | 02-20-2016 12:46 PM |
Error 6117 Fix Please | dogsareloud | Pro Tools | Intro Discussion | 7 | 02-03-2016 04:28 AM |
Pro Tools First Error -6117 | MinusE | Pro Tools | Intro Discussion | 1 | 08-31-2015 01:36 PM |
