Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 01-15-2016, 09:56 PM
Ormond Ormond is offline
Default Can't hear track being recorded when in Low Latency mode
Thanks to AVID for publishing the MBox Driver today. It works. However, when plugging the mic in and recording I cannot hear the vocal I am putting down in my headphones when Low Latency monitoring is engaged. If I de-select Low Latency Monitoring I can hear myself in the headphones.
In the full version I was using (8.03) and all versions I have used over the past 18 years I could enable/disable Auto Input Monitoring or Input Only Monitoring and hear what I was recording in Low Latency mode. NEITHER Input Only Monitoring OR Low Latency Monitoring are available under the Menu Item "TRACK." Neither are there anymore.
Is this a known problem in ProTools First or is this related to the new driver. I do not think it has anything to do with the Control Panel. Oh, which begs the question - should I enable or disable "Host Control" on the Control Panel. I have never understood what the Control Panel was for...been recording for years and ignoring it.
Old 01-16-2016, 12:35 PM
Default Re: Can't hear track being recorded when in Low Latency mode
OK - 220 people have read this so let me ask another way. Are any of you who are plugging a microphone or guitar into PT1st able to hear what you are singing or playing as you record in Low Latency mode? I can only hear what I am singing in my headphones when I turn Low Latency Mode off.
I am using the new MBOX3 driver that was published yesterday.
Old 02-01-2016, 05:42 PM
GoGoJoe GoGoJoe is offline
Sorry no one has responded to this yet. I also have mbox pro 3 on a windows platform.
Disable host control will Disable pro tools (or any daw for that matter ) to manipulate the sound. U would have to manage everything from the device control panel that would prove NOT effective. Generally you don't want to check disable host control unless you have a special reason to imo
As to the low latency mode and the sound going mute. Exact same thing happened to me. However at times it had worked with low latency monitoring on. I'm not 100%;on why it's doing this. Perhaps someone else may chime in
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1
Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT.
Old 02-02-2016, 07:11 AM
Thanks for answering.
I have not been able to fix it yet. It renders PT1st unusable for me. So I have gone back to my Mac Mini with Snow Leopard and PT 8.03.
Because I also like using my rMPB2015 I bought Logic Pro X 10.1.2. Pretty damned impressed with Logic.
pro tools 10 i cant hear my recording/recorded track cassie11 Windows 7 11-28-2012 05:53 PM
PT Native does not mute track when punching in so I hear the latency delay too...? kick56 Pro Tools HDX & HD Native Systems (Mac) 21 05-23-2012 10:20 AM
CAN I HEAR RECORDED TRACK AND PERSON THAT WILL PUNCH IN MASTERLINKSTUDIOS Pro Tools TDM Systems (Mac) 20 01-09-2008 07:04 PM
Can not hear the recorded track klrss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-12-2007 09:04 AM
can't hear audio with track in play mode slim chrispy Tips & Tricks 2 06-08-2004 07:06 AM
