WAV files not playing on Windows Machin
Has anyone else run into this problem? I bounced my tracks to a wav file. I then open up the wav file in Windows Media player and the counter (timer) is counting down like the track is playing but there is no audio. Even the the pretty little dancing waves on the screen are just sitting there.
I've also tried to open up the wav file in other programs and it just causes them to crash or it says they aren't properly formatted files. I just assumed a wav file is a wav file. Any ideas? Kevin |
Re: WAV files not playing on Windows Machin
What resolution are the WAV files? WMP only supports 16 bit files... use iTunes to play 24 bit files.
If you're not sure.. use my Header Investigator. BTW WAV files can have different types of encoding.. the most common is PCM, but they can be MP3, IEEE, etc. Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD •••••••••••••••••••••••••••• |
You can try to go into the Volume Control for Windows and make sure the Wave volume is up. Sometimes it goes to 0 and you won't hear anything from your computer speakers.
If the Icon is not in the system tray, go to Control Panel - Sound and Audio Devices - Audio - sound Playback - Volume.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I know my sound was turned on...it just wasn't playing. I'll look into the bit depth.
Kevin |
Even if the sound was turned ON, the WAV slider may be at 0. Open the Editor where I said before to check.
I understand what you were saying. The sound was on. I could play other files...just not my ProTools wav file. Thanks for you thoughts though.
Kevin |
When you bounce the Protools .wav files are they 16 bit 'Stereo interleaved'?
Bazzle |
I believe so.
Kevin |
Kevin ,
AFAIK, WMP will only play 16bit/44.1Khz stereo interleaved, regular PCM files at tops. Did your bounce specified this format ? What is the output destination of WMP...? Does this same file play back from PT LE ? good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Thank you. It was set to 24bit. I bumped it down to 16bit and it is working fine.
Kevin |
Auditioning files while playing (PT HD) | pjsaccone | Tips & Tricks | 1 | 03-15-2007 01:31 PM |
APPLE MAC PRO or The Allenstein "Quadzilla" Machin | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-05-2007 11:06 PM |
Playing quicktime files | Jeffrey Yue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2003 11:12 AM |
Windows applications not playing | Siegfried Meier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-31-2002 10:16 AM |
Playing audio files | DannyVanSpreuwel | Tips & Tricks | 6 | 10-05-2000 12:45 AM |
