Old 04-06-2009, 05:14 AM
sauna-l sauna-l is offline
Default Instrument track view toggle
Something has changed; maybe un update consequence, or I set a preference somewhere ... but it's quite annoying and I didn't find any help about it :
On instrument tracks, track view toggles between notes and velocity, while I'd like it to toggle between notes and blocks, as before.
Any clue ?
Thanks in advance
Making sounds and music. Love both.
Old 04-07-2009, 06:32 AM
mhmh mhmh is offline
Default Re: Instrument track view toggle
Originally Posted by sauna-l View Post
Any clue ?
Thanks in advance
Do you mean in Zoom Toggle? In Preferences you can tell track view to toggle to last used.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 08-30-2009, 04:37 PM
Well. Im' still using workarounds but didn't find any answer.
And no, it's not about zoom, only about "track view" , the key command
that toggles between waveform and volume (automation) on audio tracks,
now toggles between notes and velocities on instrument tracks,
while I'd want it to toggle between notes and blocks as before.
Any clue on this would be greatly appreciated; thanks.
Old 03-12-2012, 08:58 AM
kingtinker kingtinker is offline
Same problem, just posted a topic too (sorry for repeats). Incredibly annoying.
Old 03-12-2012, 09:02 AM
Found the answer! Thanks to spkguitar:
Send a message via Skype™ to spkguitar
Default Re: Toggle track view
Do you have Zoom Toggle turned on?
I bet you do. Try turning it off and see what happens. (press the e key while in command focus )
______
So you have to press the E key to get out of Zoom Toggle, which you might be in for a whole session and not even know about because if you don't set Zoom Toggle to look different than normal, you'd never know. That's the answer and it works!
Toggle track view Trazan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-13-2010 12:46 PM
Track View Toggle, Regions or Velocity the hecksome MIDI 3 06-30-2010 09:31 PM
alt+track view toggle>TDM 6.41 peterle Pro Tools TDM Systems (Mac) 3 06-12-2009 10:44 AM
track view toggle in Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2003 05:46 AM
PT HD 5.3.1 - track view toggle bug - i think. lionel wong Pro Tools TDM Systems (Mac) 4 07-22-2002 06:35 PM
