PT does NOT thruput MIDI, until i goto OMS and "wake it up" HELP
When I pull up a session, and rec enable a midi track, it does not pass midi. I see no midi level meter in the track. Only when i go to my OMS setup and do a quick "test studio" to "wake up the midi", and go back to PT do I finally get MIDI thruput..
Anyone else experiencing this? OS9.1, G4 466, Studio 4, PT Mix 5.1
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Re: PT does NOT thruput MIDI, until i goto OMS and "wake it up" HELP
I have had this problem ever since I started using USB for MIDI (v 4.xxx and 5.0 and 5.01). My work around has been to
bend the mod wheel, that seems to wake it up. |
Well, its been a few months on this one. For a while, it was working. Now on my second PT rig, Im having the same problem. I open up PT and midi does NOT pass thru a rec enabled midi track. Playing with the modwheel or anything else doesnt change anything. No midi meters in PT.
I have to go into OMS, "wake up" the midi by "testing studio" in OMS. Only then when i switch back to PT, I get midi thruput.. PT 5.1.1 G4 500 Mix++ G4Port Serial Port going into MTP/AV When I first had this issue on my other rig, someone emailed me personally, and told me how to fix it and it worked, but i forgot what is was.. Any help out there? MT
I have the same problem, not with PT but with Reason and Reaktor. I too am using a USB MTP AV. I f you find out how to fix this I'd love to know. Thanks. --wolfie
have the same problem only with my Jv-1010 sound module connected. I open oms setup and do a midi test and everything works.
g3 beige os9.2 studio64x PTLE5.1.1 |
In OMS midi setup, make sure "run midi in background" is checked...
I was reminded that , that was how i fixed it when i first had the problem... MT
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
002 rack "clicks" and Windows beeps when "Setting Up Midi" or | sw0mgt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-03-2012 03:42 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
"Midi hell" or "where did my keyboard go?" | John H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-16-2003 03:42 AM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
