Sync I/O - Machine control problems
Several days ago, I finally installed a HD system in my studio. I upgraded Mix hardware to HD, 88x interfaces to 192 and USD to sync I/O.
Since then, I have a problem with Machine control and Sony UWV 1800 Beta recorder. The situation is: I hit the play button, machine rolls back, stops at preroll point and immediately advances. When it reaches the sync point, it simply stops. When I hit play again, it repeats the whole operation and sometimes it locks and begins to play in sync and spmetimes not. Tried to use LTC, 9-pin TC, longer, shorter preroll - no change. Every machine in the studio is resolved to Snell&Willcox PAL B&B generator. I never had this problem with USD and now i loose a lot of time just waiting for PT to lock up. Help Branko HD2 G4 500 512MB |
Re: Sync I/O - Machine control problems
We have found the best Machine Control performance when using a Keyspan 28x USB adapter. We still support the SYNC I/O's 9-pin ports as they usually work well with non-linear decks. With anything but a non-linear deck, I'd use the Keyspan 28x for best performance.
Scott Wood Systems Integration Consulting Digidesign |
Also, if you're on OS 9.x, make sure you download Pro Tools 5.3.1cs7 which contains a few SYNC I/O and MachineControl fixes. Once installed, adjust the Minimum Sync Delay setting until you get the fastest, consistent lock. You can get the download at: http://www.digidesign.com/download/cs/531cs7/
-Jordan |
http://www.a-sound.com/ |
Ouch, I accidently hit the wrong button in the previous post, admin please delete
Basically what your saying is: SYNC I/O has 9-pin (even 2 ports), it sometimes works, but you'd better use an old-fashioned serial connection to your mac, via a USB to serial adapter.... What is better with the Keyspan solution ? I'll try to control an analog and digiBeta and see what happens. Greetings, Thierry
We have 2 HD3 suites, one with AVXL, the other with an old VR Virtual Recorder (PC Based). Both Suites use the Sync I/O for machine control. In the AVXL suite, the deck is used for load and layback, with pretty good success. However, in the second suite, the operator has a much harder time with faulty machine control, poor lockup ratios (successful/unsuccessful), and hassles in general. This includes driving the VR, which is pretty much tweaked ballistically for optimum PT performance. We have a spare Griffin g-Port that I have considered installing, but never imagined it would be better than the Sync I/O. Would this be a better option, providing more consistent lockup and better editing control of the VR, or should we spend more money for the Keyspan? I think I'll go ahead and throw the g-Port into the second system. But I'd still love your feedback on this issue. Thanks Brad McIlvaine Sr. Mixer/Design Henninger Media Services - Washington (aka 1150 Post, silly name change!) Washington, DC 20036
Brad McIlvaine Sr. Mixer/Designer Henninger Media Services Washington, DC 20036 |
Thank you all for your quick replies. I solved the situation with Keyspan dual...whatever.
It's working now, as I was used to with USD and Griffin port. One thing worries me: Quote:
Branko |
Hi Branko,
I have the same issues on both my HD v5.3.3 systems and have spent a long time trying unsuccessfully to resolve them. Mine are both Windows based systems, so it's not just a Mac version issue. Does anyone know if it will be better for me to use the PC COM port instead of the Sync I/O 9-pin port? Thanks, Matt |
Darkwar3,
I too went in thinking the Sync I/O 9 pin was a go, foolishly removing a keyspan adapter from my budget and my final proposal. 1 day after trying unsuccessfully to get the thing to behave "professionally", I had to go explain to my boss why I needed more money to buy a 'quick fix" for a piece of gear he had just spent $4000 on (2 systems). Yeah, it was only 100 bucks or so, but it was the principal, and the perception that I didn't do enough research that it created. Rant Over I don't know if the PC COM port will be better as I am MAC based, But the Keyspan serial adapter made our system rock. I have Dig Beta lock-up in under 2 seconds and V-1 lock-up in frames. And the scrub works really well too, just like you were at the deck. Frank |
We installed the HD SYNC i/o setup about a year ago and had problems with lockup using the Sync i/o's 9 pin ports. It seems like a farce to include an option that does not function as a professional standard.
We tried the Keyspan with a G4 933 and had problems keeping a connection with a V1. I have since tried the G-Port and had no problems since. However, I am concered that when we make the upgrade to OSX, the G-Port will not work. I have read that it is not supported. Has anyone tried a G-Port with OSX and PT 6 machine control? |
Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync | audiomark | Post - Surround - Video | 5 | 02-14-2013 03:09 PM |
machine control and sync | louisenslinproduce | Pro Tools TDM Systems (Mac) | 4 | 02-27-2007 10:51 PM |
9 pin Machine Control ports on USD or SYNC | Fritz | Post - Surround - Video | 16 | 04-16-2004 07:30 PM |
USD+Machine Control+Cannot Sync to LTC | babyseal | Pro Tools TDM Systems (Mac) | 0 | 06-26-2003 02:11 PM |
Sync & Machine Control | blanos212 | Pro Tools TDM Systems (Mac) | 0 | 02-25-2002 03:03 PM |
