Old 05-06-2022, 10:48 PM
Default Re: No audio output
And before trying to do anything with VIs you do have Pro Tools working playing back standard audio???? Like you can drag and drop a know good (e.g. commercial) mp3 audio file into the mix window. let Pro Tools create a audio track for that content and you can play back and hear that OK??? I guess if you can hear the metronome all this should work.
Old 05-07-2022, 12:09 AM
DigitalDragon DigitalDragon is offline
Anybody else have different input on this matter?
Old 05-07-2022, 12:32 AM
Start with a new empty session, not from a template, not from a copy of an existing session, start over with an new empty session. And not a cloud project.
Make sure your Pro Tools playback engine is set to the ASIO interface.
Drag and drop a known good mp3 or similar file onto that session mix window. let it create an audio track. Confirm you can play and hear that track.
Now create a single mono virtual instrument track and insert mini grand on that.
Click on piano keys in the plugin UI do you hear the piano? Do you see the VI track meters move? And just not hear anything? Make sure the VI track fader is not pulled down. (Not hearing anything if you have done the above but see the VI track meter move is possibly an IO routing problem, or some mistake like the track being in mute, or volume or other automation accidently written to the track.).
Still having problems post a screenshot of your VI track in both the mix and edit windows, especially showing the I/O selectors, also post screenshots of your setup>IO>Output and Setup>IO>Bus pages.
Old 05-07-2022, 12:47 AM
Attached are some examples of the sorts of screenshots that might help. But some shown will differ for you, but there is an instrument track here with mini grand inserted on it. In this case it is a MacBook Pro, I know you are on Windows. Mix and Edit views screenshots in this case showing the output I/O selector is set to "Analog 1-2" and the setup>IO>Output and Bus pages show this output is going to the Mac built in speakers. I'm not asking you to understand these just showing the type of screenshots I want you to share if you see meters move but don't hear any sound. The paper clip icon lets you attach image files, It's even better if you post screenshots on a good photo sharing site and just include links to them here (the mountain picture icon), that way the forum does not downscale them/make them hard to read.
File Type: jpg Screen Shot 2022-05-07 at 12.44.41 AM.jpg (41.2 KB, 0 views)
File Type: jpg Screen Shot 2022-05-07 at 12.44.08 AM.jpg (38.1 KB, 0 views)
Old 05-07-2022, 07:59 PM
Does anyone else have some tricks and techniques?
Old 05-07-2022, 09:42 PM
Sardi Sardi is offline
Have you tried what has been suggested?
Old 05-08-2022, 12:35 PM
You say you have a Presonus interface? Then you should be using the driver from Presonus and NOT the ASIO4ALL driver(which is a band-aid at best and would only be used when running the onboard sound card with PT). For best performance, do these things(in this order):
1-uninstall ASIO4ALL(you can always add it back later)
2-install the Presonus driver
3-go to Windows Sound Properties and set the default playback device to the onboard sound card(realtek?)
4-open Pro Tools and verify that the Presonus interface is the designated "audio engine".
5-open a new blank Pro Tools session and create 1 mono AUX track. Pull the fader down all the way and then insert(in Slot A) the Signal Generator plugin(its in the "Other" category). Set it to pink noise and bring the track fader up slowly. If you hear the pink noise thru your speakers and/or headphones, then you know things are working. If you hear nothing, then its probably a setting in the Presonus monitor/routing utility.
Old 05-19-2022, 11:43 PM
zedhed's Avatar
zedhed zedhed is offline
Looks like a moderator pixie has been moving stuff into one thread.
Pixie yourself.
.. I started new thread and it came here.
You are in error kinda about the info you say. But thanks anyway Disney.
I think you are mis-interpreting Darryls reply...he's referring to the moderator as being the pixie.
Darryl is not in error, do what he says and you'll be up & running.
Frankly dude, you're lucky to get any help with a bad attitude such as yours. Albee is just too kind, you should have been told to sod off.
Yeah...go watch you tube.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 05-20-2022, 01:12 AM
I understood after.
Sod off???
Old 05-20-2022, 01:16 AM
I'm up and running did not download material on pro tools. Thanks y'all. I appreciate it...
M-Audio Fast Track Pro Audio Output issue in Win7 tamal_g Windows 3 04-04-2016 07:08 AM
Meter activity but no audio output when monitoring audio input christarren macOS 4 04-17-2014 11:55 AM
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools DaveZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-12-2012 12:53 PM
OS X Audio Output mookoe2 Pro Tools TDM Systems (Mac) 2 01-09-2004 03:12 PM
no audio output on monitor output or noisy hiss Janvy ICON & C|24 0 12-03-2003 06:17 PM
